02-24-2019, 04:05 PM | #1 |
14 bolt swap?
I have a 1988 K10 Suburban that I'm swapping 3/4 ton axles into, the front I know will be plug and play, but the back will need at a minimum, a conversion U joint, does anyone know if I will be able to use my stock driveshaft, or have it shortened? the truck is stock, without a lift.
Thanks- Eric
'06 2500 HD 4x4. manual transfer case, crank windows. '88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project. My trucks don't leak oil, they mark their territory. |
02-25-2019, 01:31 AM | #2 |
Re: 14 bolt swap?
For the front all you have to do is swap the rotors and backing plates, that is unless, there is a ratio difference. And the rear shaft will need to be taken to the d-line shop and reworked
02-26-2019, 12:21 AM | #3 |
Re: 14 bolt swap?
I was worried about that... bummer, thanks.
03-03-2019, 05:13 PM | #4 |
Re: 14 bolt swap?
you think if I were to install a 4" lift I would still need the rear driveshaft shortened?
03-04-2019, 10:44 AM | #5 | |
Re: 14 bolt swap?
Theoretically, you are going in the right direction but say it will fit without modification....hard to say. Each truck is a little unique. I would suggest getting all new u-joints regardless, and Spicers is all I use. If you have a driveline shop do it, they might just check the balance too while installing. My shop gave me free install, if I bought new u-joints from them. A little more expensive than on-line, but then again, I was getting a local shop do the work and a bonus, balancing the shaft too. I just did my 3/4 ton Yukon XL driveline ujoints. Pretty easy, you'd think but after removing the factory u-joints, the new ones threw the balance off. They re-balanced a few times, free of charge because they installed. 1410 non-greasable joints I used.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
03-11-2019, 01:00 AM | #6 |
Re: 14 bolt swap?
I've been collecting parts for my Suburban 1/2 to 1 ton swap. In my notes I have "10 bolt to 14 bolt conversion joint Moog Precision #447." Fits your original driveshaft and the 14 bolt. https://www.summitracing.com/parts/mog-447 It's available through Amazon /NAPA, etc. too.
Romans 10:9 - The Truth |
