03-08-2019, 10:03 AM | #1851 |
I'm just glad to be here!
Re: How to: Ruin a perfectly good C10
You could always get a small brush to paint them once they are installed and tight. If you ever need to remove them, then you would have to touch up the paint...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-08-2019, 10:59 AM | #1852 |
Karl is right, you know. There's a reason that I have a couple of bottles of black finger nail polish in my tool cart. And no, not to touch up my finger nails, they get black enough on their own.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-08-2019, 11:15 AM | #1853 |
Agreed. Excellent ideas.
03-08-2019, 02:43 PM | #1854 | ||
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-08-2019, 03:23 PM | #1855 |
I agree with Scoti. I've painted my fair share of bolts and all of them have chipped or peeled at some point. Most have failed very quickly (days or weeks). Plated bolts may work, but the black oxide I've seen hasn't been black for more than a few months. They rust.
The touch up paint idea is a good one, but if it stands out like a sore thumb in polished form, it will be easily spotted if it's touched up too. Just keep that in mind. This is exactly why I try to leave all of my bolts raw (stainless), unless they will rust (steel).
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-08-2019, 03:57 PM | #1856 |
Powder coat is more durable than paint, but it doesn't pay off unless you have a DIY setup at your digs.
03-09-2019, 10:34 PM | #1857 |
A guy with a truck
With the engine somewhat complete, I decided it was time to get it ready to stab. First up, pull it off the engine stand where it’s been for months and swap the flex plate for a flywheel.
This setup is super simple and straightforward, using a PRW part# 1634680 which is drilled for both LS and big block clutches. Since I’m using an old Muncie (for now?), I’ll use the early style disc with 10-splines. Also installed an LS7 style pilot bearing, which thanks to GM’s consistency throughout the years, fits the old Muncie pilot shaft perfectly.
03-09-2019, 11:08 PM | #1858 |
A guy with a truck
...and then stalled at the point of having the engine mounts in place. I had assumed that the bell housing would bolt up no problem. Silly me. It hits the rear cover bolts, so I’ll either be grinding on it a bit, or ordering a new one. Oh well, the engine looks good sitting there being held up by the picker and a jack...
03-09-2019, 11:43 PM | #1859 |
03-10-2019, 04:32 PM | #1860 |
Ooooo.... I remember that point, like it was last week... Looks good brother!
03-11-2019, 09:09 PM | #1861 |
It Is What It Is
Everything looks great, Chris!
Just MHO, but have used the VHT Black Epoxy spray paint and it does a very good job. Especially, if you give it a little bake in the grille!
Kevin 65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride) 68 Chevy SWB Fleetside Custom Cab 68 Camaro convertible www.louisianaclassictruckclub.com |
03-12-2019, 10:36 AM | #1862 |
VHT's rattle can Epoxy does work nicely & is very close to the 'old school' Krylon as far as sheen & appearance when applied. But, it's not very forgiving if you don't follow their application time window.
03-12-2019, 02:12 PM | #1863 | |||
A guy with a truck
I do like the vht epoxy, specifically the satin version Truth. Some of my favorite LAPS rattle can, though
03-13-2019, 09:42 PM | #1864 |
It Is What It Is
Looking forward to it, Chris! Anytime we can get together is a good time!!!!
03-13-2019, 10:44 PM | #1865 |
A day late and $1 short...
Y'all have any idea about your next assignment?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
03-13-2019, 10:59 PM | #1866 | |
A guy with a truck
Well, we thought we were headed to TX, but it looks like we’ve now been diverted back to LA. Should be back in the south sometime in May, which means I have to get this heap assembled enough to put on a trailer, and fast
03-13-2019, 11:46 PM | #1867 |
Back to Shreveport? Oh, the damage we can do being a short 3 hour drive away!
03-14-2019, 11:55 PM | #1868 |
A guy with a truck
Bossier this time, but close enough. Watch out world!
03-15-2019, 09:22 AM | #1869 |
You need to make a trip to Lone Star Thorwdown (LST) next year, when it's finished. It's out here just north of Houston in February.
03-15-2019, 09:30 AM | #1870 |
A guy with a truck
I am straight-up stoked about these
Rick’s custom upholstery is rocking it. It’s awesome to see something that came from my brain, then onto piece of paper, turn into reality. They are also working on a dash pad and visors to match
03-15-2019, 10:21 AM | #1871 |
Very nice!
03-15-2019, 10:41 AM | #1872 |
Damn! Them some fine looking pieces you got there. Good work!
03-15-2019, 12:30 PM | #1873 |
That interior is going to be outstanding! Nice job
03-15-2019, 01:28 PM | #1874 |
Sweet! Those look great and will compliment your truck nicely.
I want to upgrade all my stuff now.... It's hard to resist the urges, heck my stage 1 build is already more like a stage 1 and 2 combined.....
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
03-15-2019, 02:50 PM | #1875 |
Blue Houndstooth? What's the color/info on the other material? I'm on the hunt for retro (appearance & color) blue material that doesn't break the back.
