Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-04-2019, 12:57 PM   #26
oem4me
Re: 64-66 GMC Cab Big Window Part Out Power Brakes
Long shot request: Any chance you have a complete lock cylinder set off this truck (like the one pictured) ? Glove box a plus, but not critical. Thanks.
Old 02-04-2019, 02:06 PM   #27
paulspickupparts
I can check but it is getting harder and harder to get a matched set . Usually over the years something has been changed out. I might be able to come up with a set like the one pictured but no key. Pretty sure you are aware that you could have a locksmith make a key and match the set. Thanks .
paulspickupparts is offline   Reply With Quote
Old 02-04-2019, 02:31 PM   #28
oem4me
Yeah, but a couple of lock cylinders on the subject truck seem to be so worn out that a popsicle stick would operate them. I thought it might be less work to acquire a matched set.
Old 02-04-2019, 03:01 PM   #29
paulspickupparts
Ok , mine are probably not much better. Nebraska farmers were kind of hard on stuff. Thanks
Old 02-05-2019, 07:00 PM   #30
Madmartigan
Have any other parts in Palomino Tan? Hood?
Madmartigan is offline   Reply With Quote
Old 02-05-2019, 09:04 PM   #31
paulspickupparts
Sorry no hood . Just the cab as shown . Thanks
Old 02-06-2019, 07:25 AM   #32
rickoner
If you do end up cutting the cab, how's the area around the dimmer switch?
rickoner is offline   Reply With Quote
Old 02-06-2019, 10:40 AM   #33
paulspickupparts
I can check on the dimmer area. About 10 degrees right now so probably will not cut for the next week or so. How big of area do you need ? Thanks
Old 02-06-2019, 09:24 PM   #34
Pontitruck
Pontitruck's Avatar
If it's a low hump cab I might be interested in part of the hump, mine has been modified.
Pontitruck is offline   Reply With Quote
Old 02-06-2019, 11:31 PM   #35
rickoner
No worries on time. Just whenever you can get to it brother. I would like to find a piece that's from the left side (under kick panel seam) and maybe 2-3 inches around the switch recess.
Old 02-09-2019, 08:58 PM   #36
Pontitruck
Pontitruck's Avatar
Hi, was just wondering if you could help? Thanks
Old 02-12-2019, 03:33 PM   #37
paulspickupparts
Matt , just to let you know that I received your payment on the outside trim. I included all the fasteners. Was shipped today via USPS Priority . Tracking sent in pm.
Thanks again. Paul
Old 02-12-2019, 03:35 PM   #38
paulspickupparts
Sorry , I missed this . This truck is a high hump but I have a low hump I am also parting. I might be able to help. Let me know how much area you need . Thanks
Old 02-12-2019, 03:47 PM   #39
blazin71K5
blazin71K5's Avatar
Thanks again. Paul
Thanks you very much, Matt
71 2wd k5
67 Nova
blazin71K5 is offline   Reply With Quote
Old 02-12-2019, 09:02 PM   #40
Pontitruck
Pontitruck's Avatar
Thanks Paul, I thought I was invisible for little bit there. The guy I got my project from was putting in a 5 spd so he grafted in a piece to raise it up even with the raised portio. I could use a section like the picture I've added. Let me know what you've got.
Joe
Old 02-12-2019, 10:43 PM   #41
paulspickupparts
Joe
Hi Joe. I will look at the low hump and see what kind of shape it is in.
Old 02-13-2019, 06:33 PM   #42
GMCNUT
GMCNUT's Avatar
You do realize any locksmith can change a non-matched set into a matched set in about 30 minutes right? next to none of my 12 trucks had the matching locks and now they all do - easy as pie and cheap. Just manipulating the tumblers to match is all it is -
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 02-15-2019, 08:55 AM   #43
blazin71K5
blazin71K5's Avatar
Paul,
I received my trim parts yesterday, they look great. Thanks for such an outstanding job of packaging! Matt
71 2wd k5
67 Nova
Old 02-15-2019, 01:08 PM   #44
paulspickupparts
Thanks again Matt . I appreciate your business . Paul
Old 02-19-2019, 04:05 PM   #45
blazin71K5
blazin71K5's Avatar
How about the engine id tag on the drivers side kick panel area.
71 2wd k5
67 Nova
Old 02-20-2019, 12:38 PM   #46
paulspickupparts
Hi Matt .
Going to wait just a bit to see if the whole cab sells . If I get impatient , quits snowing and the weather warms up. I will probably start wacking.
Old 03-17-2019, 09:43 PM   #47
cvalcore
cvalcore's Avatar
How is this area of the cab? And the front door pillers?
cvalcore is offline   Reply With Quote
Old 05-06-2019, 08:58 PM   #48
rcsbls2
I want the interior sheet metal around rear window. Spot welded to window frame, door jams, then cut roof to leave me lip that’s attached to metal. Wanting to make my truck big rear window. Just shoot me a price !
07 Silverado Belltech 4-7 LS2 on stand
66 swb fleet in garage
my build thread 76 stepside (painting for buddy)http://67-72chevytrucks.com/vboard/s...d.php?t=645332
rcsbls2 is offline   Reply With Quote
Old 05-06-2019, 09:08 PM   #49
paulspickupparts
400.00 for what you are talking. . Bare whole cab would be 500.00 if picked up. Shipping usually kills the deal. Any chance you can pickup in Nebraska.
