Old 11-24-2018, 08:11 PM   #1
C10matt
C10matt's Avatar
Another turbo ls
This has been a while coming. The truck is a 64 i took on trade a couple years ago and didn't have a plan for but after driving a friends malibu with a turbo 5.3 it was just so versatile Ive decided on doing something similar.
So far I have a 1999 5.3 with a elgin 1840p cam and pac springs, coming shortly is a 7875 and log manifold. Trans is a th400 with a summit nitrous 10" 3200 converter. The truck has a open 3.73 12 bolt from a 67 which I have a posi coming for. The suspension is drop spindles with 2" drop springs in front and 4" drop springs in the rear where I'll be adding a c notch and 2" blocks. Lots more to come...
C10matt is offline   Reply With Quote
Old 11-25-2018, 03:10 PM   #2
C10matt
C10matt's Avatar
Re: Another turbo ls
I had time this morning to get some stuff done. Cam and valve springs installed, converter mocked up which was a win because i was figuring on having to elongate the flex plate holes but the summit converter came through and the inner bolts lined up!
$20 spacer and the 5.3 bolts up
Waiting on some stuff to do the turbo feed and drain which i believe i'll put in the timing cover, i just don't wanna drill into my new f body pan. After that in it goes grease and all
Old 11-25-2018, 04:04 PM   #3
SkinnyG
SkinnyG's Avatar
I am KEENLY interested. I bought the VS Racing billet 7875 kit for the LQ4/4L80E I have for my '61.
I need to live vicariously through you until I can begin my truck.
Please post LOTS of pictures.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 11-26-2018, 01:24 PM   #4
Notch1988
Notch1988's Avatar
Same here! Following this one too.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 11-26-2018, 06:08 PM   #5
C10matt
C10matt's Avatar
Thanks for the interest, I love the 61! I'd have gone with a 6.0/4l80e but I had the th400 already and I wanted drive by cable mostly I didn't care if it was a 4.8 5.3 or 6.0 for what i'm doing.
Old 11-26-2018, 06:22 PM   #6
C10matt
C10matt's Avatar
Today i got in a test fit of the motor and checked to see how the drivers side truck manifold would fit, its close but with the flange chopped off and V band it i think it'll work out.Name:  IMG_0553.jpg
random truck pic
I was concerned as about these cpp frame mounts that were with the truck but the f body pan seemed to fit okay
Old 11-26-2018, 06:30 PM   #7
C10matt
C10matt's Avatar
Heres a top view
The new crossmember which came today and i'm quite pleased with
Old 11-28-2018, 05:06 PM   #8
C10matt
C10matt's Avatar
My 2" blocks and c notch showed up today, so i figured i throw the blocks in to see how the truck will sit before i do the rear end up. I was shocked to find how much higher it is then my orange truck which has 5" drop springs and 1" blocks both trucks have a 6" rear drop total. Now the orange truck has been together for about 12 years so I know its sacked out some in the rear (which i like) just didn't realize it was that much. Now here's some pics
Once i get the motor and trans in I think I'll be good with how it sits.
6" drop done with newer 4" springs 2" blocks
Heres my orange truck for comparison of 6" drop with sacked out 5" springs 1" blocks
Both trucks are sitting on 15" rims
Old 11-29-2018, 07:33 PM   #9
C10matt
C10matt's Avatar
I got the motor and trans in today and the timing cover drilled and tapped with 1/2" npt for the turbo oil drain along with drilling and tapping the oil cooler block off with 1/4" npt for the oil feed. Now if my log manifold would show up.... anyway here's a couple pics
greasy mess looking for a home
I thought the truck pan would be a little low so I sprang for the f body pan but looking at it in the truck I think would have only hung a little bit below the crossmember though being a cast pan I'm glad its tucked up there
Old 11-29-2018, 09:54 PM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Following
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is online now   Reply With Quote
Old 11-29-2018, 11:54 PM   #11
SkinnyG
SkinnyG's Avatar
Is the next pan hanging about an inch or so under the frame, the tranny pan?
Old 11-30-2018, 02:12 PM   #12
C10matt
C10matt's Avatar
Yes it is, I normally would use just a steel truck pan on the th400 but this was already on it.
Old 11-30-2018, 02:21 PM   #13
C10matt
C10matt's Avatar
I got my log manifold today which is very exciting now I can see how things are going to fit and do the hot side.
Also chopped the flange off the drivers side truck manifold, fits nicely
Old 12-02-2018, 04:57 PM   #14
C10matt
C10matt's Avatar
Well today started off with big plans to get my posi in but I didn't have enough carrier shims left from the last time i did a rearend to get it right. So one more thing added to the list of needs. I did get one C notch welded in though. In the mean time i gotta research what size inter cooler i can make fit with minimal butchering of the core support. It feels good to be working on this truck instead of it just taking up space.
Old 12-03-2018, 01:15 AM   #15
Captainfab
60-66 Nut
Where did you purchase that turbo log manifold?
Old 12-03-2018, 12:32 PM   #16
C10matt
C10matt's Avatar
That is an eBay cast manifold from a company called race mmi. Its actually for a 2002 style truck they said but it looked just the KB racing one that I was gonna get. Long story short the price was right and I didn't have to wait so i took a chance and it fits nice so far.
Old 12-03-2018, 03:38 PM   #17
aggie91
I'm just glad to be here!
aggie91's Avatar
Following...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-06-2018, 07:29 PM   #18
C10matt
C10matt's Avatar
Got my carrier shims and was able to finish jamming the posi in. Also finished the c notches and got the truck back sitting on the ground.
This rear end is kinda temporary I'd prefer a little higher ratio but I just can't justify spending big money on a truck 12 bolt with its small pinion and only 30 spline axles, if decide to put stickies on it i'll spring for a 35 spline S60 or 9"
Old 12-06-2018, 09:39 PM   #19
SkinnyG
SkinnyG's Avatar
Do you have a link to the ebay ad for that manifold?
Old 12-07-2018, 05:54 PM   #20
aggie91
aggie91's Avatar
I could not find one on ebay, but I know this guy has done some cast ones in the past.
https://www.facebook.com/fahlerspeedandperformance/
Karl
The LST Challenge:
Old 12-07-2018, 09:38 PM   #21
C10matt
C10matt's Avatar
Yes! I wanted one of the fahler ones his were the best deal for sure. When you look up racemmi do it without the space, my bad for not putting it as one word in the prior post. Its a hot parts kit, if you wait for one of those 15% off eBay deals its not too bad I thought. I'll be butchering the crossover some as it hangs too low for my taste but it did fit up there. I also don't want the wastegate down there, Ill probably be putting it on the turbine housing. Overall I'm pleased with the kit as far a deal I'd say its fair for what it is, with the 15% off of course.
Old 12-11-2018, 06:25 PM   #22
C10matt
C10matt's Avatar
https://www.ebay.com/itm/Turbo-Hotpa...!-1:rk:10:pf:0
I got the link to show up finally
I also been getting a bunch of small stuff done including decapping the stock truck injectors which wasn't too bad as long as you have a soft touch, now i need to get them flowed
Old 03-19-2019, 12:23 PM   #23
C10matt
C10matt's Avatar
I finally got some more stuff. VS racing 7875 billet and a cx racing intercooler 25x12x3 which looks like it'll fit nicely with only cutting for the elbows. Now to get to work haha.
Old 04-25-2019, 12:19 PM   #24
C10matt
C10matt's Avatar
Got my M60 which consists of 3.54 clutch posi. I also got my 30" tall street tires
Old 04-30-2019, 03:55 PM   #25
Slappyracecars
What are you doing for a motor wiring harness?
Slappyracecars is offline   Reply With Quote
