#251 |
![]() Join Date: Aug 2004
Re: Best "Rake/Stance" for a Hot Rodded 60-66 C10?
Front:2.5” spindles, 1.5” ECE drop springs
Rear: airbags 40 psi Fr/rr shock relocators Front sway bar, lowered mount
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#252 |
1962,
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#253 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Old school rake
#254 |
At my worst I'm at my best |
#255 |
1.5 coil cut from stock front springs. Bump stop brackets completely removed. CPP disc/drop spindle kit, unknown used drop rear springs, drop blocks, small pipe notch, stock front wheels with 1.5" bolt on spacers, 8" vintage aftermarket chrome reverse wheels (slightly less backspacing than 8" blazer wheels), 215/75 and 235/75 tires. The front wheel spacers really help fill out the fenderwell while keeping the skinny front wheel/tire look.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#256 |
Here's my 64 .....5.5" front and 8" rear. Perfect stance in my eyes.
64 short fleet |
#257 |
old school rake
1961 c10 longbed - gone 1964 c10 swb |
#258 |
It's Better With Nitro
Not the best, but here's how my '63 ended up. I kept it pretty close to my old Super Gas/Street Chevy II.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#259 | |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#260 |
I'm not sure why people are still posting on this thread. I posted my truck a long time ago.
#261 | |
My problem is I'm still stuck in the late 70's early 80's when the hot rods were jacked up in the back. ![]()
#262 |
My dropped patina-ed GMC BBW SWB ……… The Hag
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
#263 |
This is a great thread. A lot of beauty trucks in here.
#264 |
#265 |
Thanks. 2 1/2 inch drop spindles and 2 inch drop springs in the front, and 4 inch drop springs in the rear. About as low as you can go without hitting anything or bagging it.
#266 |
You do have a vary nice stance but I think he was talking to "Joe dirt". At least that is who he quoted.
#267 | |
unsure, it was done by previous owner...front coils are cut, rear leaf springs has some leafs taken out of the pack...it looks to be close to a 4/6 drop ![]()
#268 | |
#269 |
I took that photo on Black Friday last year. Figured it was fitting to drive that vehicle that day.
![]() I've got it all blown apart currently. Finally painting the front clip and installing a Vintage Air setup. |
#270 |
![]() Join Date: Feb 2014
That actually goes back to the 60s I also remember when it was just the opposite dropped in the back jacked up in the front
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
#271 |
Junior Member
![]() Join Date: Oct 2014
2 1/2 drop spindles 1” drop coils in front 3” drop coils in rear.
#272 |
I like it especially because it makes a long bed look mean.
#273 |
Before on the left: CPP 2.5" modular drop spindles, 4" lowering springs, 454 w/iron heads. Lots of lower control arm scraping on semi-bumpy roads.
After on the right: CPP 2.5" modular drop spindles, 3" lowering springs, 454 w/iron heads. No more scrapes. Rears combo lowering springs and blocks.
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
#274 |
![]() Join Date: Mar 2011
Here's mine. 2 1/2" drop spindles & 1" drop springs in front. 5" drop springs in the rear. no bed yet or full tank of gas so it will probably come down another inch or so in the rear.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
#275 |
Saw this coming back from Longview yesterday.
