Old 03-25-2019, 05:47 PM   #426
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: What did you do to your truck today.The 3rd chapter
Just finished this water pump. I brushed it on, meaning I had to do the bottom first and treat the metal twice. Thought for sure the metal prep would leave a mark on the painted backside. This POR15 is bullet proof, didn't leave a mark.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-25-2019, 07:25 PM   #427
Grumpy old man
Grumpy old man's Avatar
Rotors on , Willwood brakes should be done tomorrow getting close to dropping it back on the ground ! Next to finish the Redhead power steering .
Old 03-25-2019, 11:07 PM   #428
89AKurt
89AKurt's Avatar
Fun to see real work being done by others. Love the meme "buy a C-10, it will be fun, they said".
Does this qualify for doing something, added Angry Bird eyes.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-25-2019, 11:17 PM   #429
SoCoC10
SoCoC10's Avatar
First bath
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 03-26-2019, 12:20 AM   #430
71CHEVYSHORTBED402
Nice Grumps
Tony
Old 03-26-2019, 07:27 AM   #431
Grumpy old man
Originally Posted by 71CHEVYSHORTBED402 View Post
Nice Grumps
Thanks , I'm sure you can attest it sure would be nice if all these costly steering and suspension / brake parts came pre painted / coated . I just can't bring myself to bolt it all together raw and then watch it rust up . I'm building these trucks to be driven and still look good down the road , I have plans for the next one as a Sunny Sunday only cruiser
Old 03-26-2019, 09:48 PM   #432
Thrill4130
Active Member
Thrill4130's Avatar
I got the top and one side trimmed down to fit on shortbed.
Thrill4130 is offline   Reply With Quote
Old 03-27-2019, 07:30 PM   #433
71CHEVYSHORTBED402
Met this guy who lives two miles from me that does ceramic, powder, paint, weld, metal fab. etc. etc. His shop is behind his house with a complete set-up and no expense spared. Anyway, he sent these pics. of my manifolds.
The first pic is of the RH manifold down to metal. I found it in complete ignorance early in my education. I was convinced the RH manifold on my truck was a replacement, because the part number wasn't in sequence with the left.........At any rate, GM did make a RH manifold that was in sequence (RH 45, LH 46). Same manifold as the more common 353030, only earlier production. Better shape than my 30, so worked out anyhow......Plus they match
Tony
Old 03-27-2019, 11:47 PM   #434
cornerstone
cornerstone's Avatar
Disassembled front clip, minor rust repair, sanded and primed core support and inner wheel wells.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-28-2019, 12:05 AM   #435
3757chevy
3757chevy's Avatar
I installed new hood springs , replaced dimmer switch , and installed brake lever cover.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 03-28-2019, 01:27 PM   #436
Speedracer39
Speedracer39's Avatar
Finally installed my new motor. Need to order a new set of headers and finish installing the accessories
Speedracer39 is offline   Reply With Quote
Old 03-28-2019, 05:13 PM   #437
BugzC10
BugzC10's Avatar
Took er out for an oil change & Lube.....Valvoline VR1
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-28-2019, 05:29 PM   #438
71CHEVYSHORTBED402
Nice truck
Tony
Old 03-28-2019, 05:32 PM   #439
BugzC10
BugzC10's Avatar
Nice truck
Thanks! Looks it’s best at 20+ feet...LOL
Old 03-29-2019, 08:22 PM   #440
71CHEVYSHORTBED402
Had these ceramic coated. Zep suggested that early in my ed. and glad to have done it. Early take off heat stove and nice, but you got to get through the rust. He put an extra coat on it, and as stoves go it has a nice heavy feel.
Just for looks, I always wanted the stove and pipe, but with ceramic this and that, I suspect it won't support a divorce choke. Would really like a divorce choke, learn how they work and that, but the parts were missing when I tore this down anyway. So unless you guys can talk me out of it stove pipe with an elect. choke.
Tony
Old 03-30-2019, 06:37 PM   #441
72c20customcamper
72c20customcamper's Avatar
New steering box. And since the right front tire was off I checked the brakes. Everything is new lines cylinder and linings. Also was able to take off the holder screws with just a screw driver. Absolutely no rust on the drum. Checked the other brakes all the same. Was gone over at sometime before I bought it.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-30-2019, 07:58 PM   #442
66clow
66clow's Avatar
Laid down some primer
66clow is offline   Reply With Quote
Old 03-30-2019, 09:28 PM   #443
72 Super
72 Super's Avatar
Originally Posted by SoCoC10 View Post
First bath
Looks good! Do you have any interior and engine compartment shots?
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 03-30-2019, 09:29 PM   #444
evilokc
pulled mine out of the garage to make room to fix something broken during my move then pulled it back in. still leaking badly and seems to be really rich. holly carbs are terrible at sitting and maybe ive let it sit to much the last month while I was getting the new house/move done. I will be back to loving it soon enough.
evilokc is offline   Reply With Quote
Old 04-01-2019, 09:02 PM   #445
OregonNed
OregonNed's Avatar
Yesterday was another beautiful day here in Washington, so I took a cruise, and cleaned her up a bit. I'm starting to use a Go Pro that was given to me for my birthday back in 2013 (practicing for a trip my wife and I are taking to Italy and the Greek Islands in July). Decided to take a walk around video of my truck (that didn't turn out that well), but here it is...
https://www.youtube.com/watch?v=sokv63eqAfE
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-01-2019, 11:08 PM   #446
zicc1835
zicc1835's Avatar
beautiful ....
zicc1835 is offline   Reply With Quote
Old 04-01-2019, 11:35 PM   #447
Chris_oz
Chris_oz's Avatar
I got tired of trying to get my old distributor to run as it should....so I fitted a new HEI unit.
Works perfect and timing curve just as I wanted.
Even the Tach still functions as it should.
Goes so much beter, now it will spin the tyres if you like, or sit on 70mph with ease.
Chris_oz is offline   Reply With Quote
Old 04-02-2019, 01:29 AM   #448
89AKurt
89AKurt's Avatar
Got the slotted mags on. The wheels are a whole story unto itself, ever since I got them for the previous '69.
1968 Long Bed
Old 04-02-2019, 03:55 PM   #449
beaterku
beaterku's Avatar
Pulled the trigger and finally ordered all of the fuel and trans lines for my project from Summit. It's been in my cart for a month now. Don't want to rush in to these things.
beaterku is offline   Reply With Quote
Old 04-02-2019, 04:48 PM   #450
72c20customcamper
Toasted my trans in the 72 yesterday. Dont really know what happened. She started chattering on take off then before I got to my place chattered at all shifts. Pulled the pan and it's full of metal. Going to the shop as soon as I replace the trans cooler lines on my 3500 CTD. been putting it off but its leaking real good now.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
