03-13-2019, 07:59 AM | #76 | |
Re: Intermittent power loss (need help troubleshooting please)
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
03-13-2019, 10:18 AM | #77 |
gas to the air cleaner? Are you talking about the flapper valve in the snoot of the air cleaner? I just checked it. That valve is fairly stiff and defaults to the open position (fresh air, not exhaust air). It has a vacuum port on it, but it was disconnected during the test. I just tested it with a vacuum pump. It's definitely broken. Does not hold vacuum and does not close. I don't see how this could be causing the vacuum drop during cruise speed as it was disconnected during the test, but I definitely need to fix it.
03-13-2019, 12:28 PM | #78 |
I wanted to remove the air cleaner as a possible source of air restriction, so I remade the video with the air cleaner off:
https://youtu.be/S_2tQ-CapG8 And then immediately after that video I made another video showing how it behaves when restarted immediately after a stall: https://youtu.be/ZSGQz21wrsI I also made these videos with the engine cold to prove to myself that I could make it stall cold or warm. I think this indicates it's probably not vapor lock too. I checked the exhaust pipe under the truck. There is no catalytic converter I can see, just a muffler. |
03-13-2019, 02:08 PM | #79 |
there is a valve in your exhaust with a metal hose that runs to the botom of the air cleaner horn , that is the valve I was referring to , most remove it
03-13-2019, 02:40 PM | #80 | |
The spring broke, but it moves freely when I move the lever. I suppose it's possible it's blocking the exhaust, but it doesn't feel like it's become detached from the rod. I would have to the intake manifold off to know for sure. |
03-14-2019, 09:36 AM | #81 |
You've ruled out ignition , You have compression , Have you checked the fuel lines all the way to the tank and the in tank pick up ? Your videos sure look like fuel starvation to me, collapsing fuel line ? . If you slide the seat all the way forward you should be able to pull the sender / pick up from the tank . LockDoc suggested it 2 months ago
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 03-14-2019 at 09:57 AM. |
03-14-2019, 12:18 PM | #82 | |
03-14-2019, 02:52 PM | #83 |
FINALLY a test that makes sense! It is indeed fuel starved. I didn't catch it before because pressure starts high and slowly declines under sustained throttle. I made a 3 minute video with the fuel gauge attached showing the problem:
https://youtu.be/D8EWqHjmkqA I guess the next step is to remove the fuel tank and check the sock. Thank you for the suggestion! This rocks. I feel like I finally understand what is going on now for the first time. |
03-14-2019, 04:00 PM | #84 |
Don't thank me ,Thank LockDoc ... I just re read your thread and noticed it . You don't have to pull the tank to replace the pick up / sender just move the seat forward and lean over it . also check the hose under the truck . Old guys RULE !
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-01-2019, 11:09 AM | #85 |
UPDATE:
Removed sender. Filter sock was definitely falling apart, but I was dubious that it was enough to block flow. Ordered a new sender. Went on a vacation out of the country for a week. My new sender had arrived when I got back. Installed it last Thursday, I think. Replaced the two soft lines between the frame rail lines and the tank at the same time. It still exhibited the same behavior. I knew at this point it was either the hard line or the rubber hose between the pump and the hard line, so I reached down and traced my hand along the rubber hose immediately after a stall. Sure enough, there was a kink in the hose right where it met the hard line. I had checked this hose previously and it felt and looked fine, so I think what was happening was that it had collapsed internally and as it ran pressure built up, causing it to kink. Replaced that hose and haven't seen the problem since. We rebuilt one carb then bought a remanufactured carb when the rebuilt carb didn't do the job. I ended up keeping the remanufactured carb because it came with a nipple on the float vent (my old carb didn't have a nipple, remember). The old carb ran way rich and the new carb ran way lean, according to the spark plugs. The old carb's metering rod arm was adjusted to proper specs and the new carb's metering rod arm was a few millimeters high. So we split the difference and lowered the new carb's metering rod about a millimeter and a half. After a few days of running successfully I pulled the truck into the garage again and pulled the number 1 spark plug. It looks nearly perfect to me, so I guess we nailed it. The truck gets much better mileage now. Did I have to rebuild the carb to fix this intermittent problem? No. Absolutely not. If I had run the vacuum test and fuel pressure test for longer than a minute before I removed the carb I would have found the problem and been able to fix it. Am I sorry I removed the carb and rebuilt it? Hell no. I loved learning how to do this and the vehicle gets much better mileage now. I'm also now confident that this motor is in pretty good health and will last my son a while longer. Anyway, thanks to everyone who commented for all the help. Hopefully this saga will help someone else with the same problem identify their problem quickly and resolve it faster than I did. |
04-04-2019, 09:57 PM | #86 |
Congratulations on getting to the bottom of the problem. Your tenacity is admirable.
And thank you for the follow up post on the solution.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
