Truck wrecked
So it happened. My kiddo finished his new motor/trans setup (it was sweet!). Has been driving his `68 long bed for about a month since. Then recently someone pulled out in front of him and he was unable to stop in time. The result...quarter panels, hood, wheel wells, bumper, core support, etcetera. Biggest problem is frame. Front end of it is bent, basically up to first cross member where remainder of energy was absorbed.
So now we're looking at options. Don't know the feasibility or costliness of straightening the frame. That would be most palatable I think, if doable and not too costly. So looking at that vs. other ideas... - fix frame. - A donor frame, which is essentially a new truck build. Time and availability for the effort is a bit problematic. - Cut off front end of frame and weld in new donor. Just as bad as frame replacement? - Part out the truck, maybe using his motor and trans in something else, and forget it. This one isn't exciting. It's been a lot of work and in the family since new. That and I don't really have the space to have a partially assembled truck remainder laying around. - Sell trying to recoup at least what he has in motor and trans, not to mention A/C and other stuff. - Other ideas? Basically looking for some input on best likely route to recovery. Sorry if you see remnants of this post in other forum. can't seem to pick the right one this morning and moved it. ;-) Last edited by DoobieBrother; 04-04-2019 at 10:51 AM. |
Re: Truck wrecked
Frame straightening can get costly, but when compared to the amount of work required for a full frame swap it would be worth checking into. Try to get a "frame guy" to come see the truck first. This would save the tow bill to and from the shop if it's beyond straightening.
I hate to hear about your misfortune and hope all involved are in good order. And, I would hate to see the truck given up on. Try posting the pictures using the forums "Manage Attachments" function under the "Go Advanced" button that is below the "Quick Reply" box. Maybe you can get some responses from members here with straightening experience.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
![]() ![]() Join Date: Jul 2002
Re: Truck wrecked
Using his motor and trans in another truck would probably be the easiest/cheapest fix, just not sure what you have access to in your area.
All about them K’s
![]() Join Date: Jun 2014
Re: Truck wrecked
If you can find one a frame swap isn’t that terribly bad. Can be A little time consuming depending on how much time you’ve got to work on it. That’s the direction I would go if it’s bent bad. If it’s not too bad I’m sure a frame shop could pull it straight again. Obviously all this depends on how bad you want to save the truck or how attached to it you are.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Re: Truck wrecked
Bummer to hear the news. Can't offer any advice based on experience but I'd start with your insurance company and find out what they're going to do as far as dollar amount on coverage. Personally I'd source a frame and start rebuilding. Hopefully insurance will give you enough to do some upgrades.
Re: Truck wrecked
BTW, if anyone happens to have any "frame guy" suggestions in DFW, TX area (particularly near McKinney), love to hear.
Re: Truck wrecked
You can try straightening it yourself with a come along
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Re: Truck wrecked
Yep remove the bent sheet metal. Hook it between two stout trees and use a come along to pull on it. may need to get a section of RR Track and chain it to the frame in a couple of places and use a jack. If your frame isn't bent or warped from the front suspension crossmember back the alighnment and handling will not be effected.
#9 | |
Re: Truck wrecked
I ended up working with Loaded Dice Speed Shop in downtown Frisco ( LD Automotive ). They straightened my '67 frame and did some minor body work without any issues...couldn't hurt to give them a call... -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#10 | |
Re: Truck wrecked
Re: Truck wrecked
I have a frame here in northwest arkansas if interested
1972 Cheyenne Super..owned since 1978 1972 Surburban 4x4 1972 Cheyenne 4x4 3/4 ton.....sold 1972 Cheyenne 2wd...named Death Row |
![]() Join Date: Nov 2004
Re: Truck wrecked
Ugh, that looked like a really straight/clean truck.
Based on your pics, that frame may have moved in a couple directions. Frame swaps are not that bad. I'm from NY (rust empire) and my dad's done a ton for body/frame swaps. Clean and rebuild anything that needs to be on the frame now. Remove the bed, leave it outside. Remove the front clip, leave it outside. Remove the cab and set aside. Swap the engine/trans while the frames are side by side. You just have to set back and plan it out. The front clip, radiator and all can come off as one piece. Make sure ALL wiring and steering stuff is loose and all that can come off with the cab... No joking, my dad has swapped body/drivetrains on squarebody 4x4's by himself over a 3 day weekend with a running truck sunday night. He does have a backhoe and is a master with a torch though.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-04-2019 at 04:34 PM. |
Re: Truck wrecked
Remove all the front sheet metal, take some pics from the side, above and from the front, and get a quote on straightening the frame. If that’s too costly or too close to the cost of another frame then frame swap it.
Frame swap isn’t that bad if you plan it out. If you need to swap brake and fuel lines, do that first. Then drivetrain, then cab, bed and finally new front sheet metal. If one person put in 2-3 hours a day during the week, plus 2 full days (the weekend) they could easily have it done in a week. Just need some extra hands for moving the bed and cab. |
Re: Truck wrecked
Have you crawled under it looked at the cross member, checked between the bed and cab to see if the gap is straight? Is it just the front frame horn? If so use a come along. Take some measurements see if its square or where it gets out of square.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
#15 |
Re: Truck wrecked
When I got my 1967 short bed, it was apparent the truck had been crashed at one time on the front left side. Before doing some body work in preparation for paint, I located 2 guys here in my area that still straighten frames.
Without going into detail, the results never did meet my expectations. And fitting either aftermarket or factory panels can be a real challenge in getting the doors, cab, and hood to line up properly. Might be best to source another truck. There are plenty of clean long bed C10's here in Arizona for reasonable prices. Of course you are in Texas, so that makes a difference. Will be interested to see which way you go. In hindsight, I wish I had bought a good straight donor frame on my truck and done a swap. Short bed stepside 67's are really hard to find. Long bed 68 and up trucks are in a different category. Good luck and keep us posted. |
#16 |
Re: Truck wrecked
Once the sheetmetal is off have a good look and post up some pics of the bend. Ask around at cruise nights and car shows in your area for a good body shop that isn't afraid to work on older vehicles. Ask at any specialty shops who build hot rods or race cars too as they may have a contact. I have seen some frames fixed that I thought no way they would come back, but they did. Steel has a "memory" for lack of a better term and a good frame guy will get it back pretty good.
#17 |
![]() Join Date: Oct 2011
Re: Truck wrecked
Okay...quick key opening question:
was the truck insured when this happened? C.
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#18 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Truck wrecked
My truck got a frame. It was bent in spots we didn't see until the cab and bed were off.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#19 |
Re: Truck wrecked
That's a bummer about the truck. Hope your boy is ok.
#20 |
Re: Truck wrecked
Most all insurance companies will total the vehicle. They will say price to repair will exceed the value. What is the value? The value would be what most similar condition pickups are selling for right now. Take an insurance check for around $5500-$6000 and start looking. https://sfbay.craigslist.org/eby/cto...839580153.html IMO, Ayou can fix it on your own, but you'll have a truck with salvage title and probably much more money into it than $5500.
#21 |
Re: Truck wrecked
Personally I would leave it together until you have the parts to fix it. A frame shop should be able to straighten the frame or you could do it your self. It’s a easy fix if you Decide to swap frames you are looking into a restoration by the time your done.
70 SWB STEPSIDE 70 BLAZER 09 challenger Last edited by OARNGESI; 04-06-2019 at 02:44 PM. |
#22 |
Scrapper 1
Re: Truck wrecked
There are a few of us older people that have gone to extra ways on protecting are front ends from people that pulling out in front of you is Just OK. Most old timers use to tell me to Weld in a hitch to the front of your truck and Leave the Ball sticking out. The reason for that if Most of the time when you have a front end crash one of your Farm Rails gets bent. But with the hitch up front, it Keeps your horns from buckling saves the Frame if you look at trucks that have Rear Trailer hitches and one that does not the ones without the hitches have bent Fames. Just a though
