Old 04-05-2019, 09:49 AM   #626
Hammered 77
Hammered 77's Avatar
Re: "Crewcab Jake" the 84 to 74 conversion
Ken, I thought of the 67 c 10 back up light might be close to the right size. May be too big.
Hammered 77 is offline   Reply With Quote
Old 04-06-2019, 09:54 PM   #627
FunKing85
FunKing85's Avatar
This is a fantastic thread, very detailed and informative. I work on my truck solo, on a budget, when I can, to see the professional version and tactics helps me learn so much. Keep up the detail and the work! i'll be checking in regularly.
Jake, Merritt Island, FL
"If You're Gonna Be Dumb, You Gotta Be Tough"
FunKing85 is offline   Reply With Quote
Old 04-06-2019, 10:46 PM   #628
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for joining us. I try to keep my builds clean and simple with a high level of detail that can be duplicated by the average Joe.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-06-2019, 10:57 PM   #629
N2TRUX
Happy to be here
N2TRUX's Avatar
This week was extremely busy so my shop time was non existent. This morning I finally found time to fabricate the mounting bracket that needed to be replaced. With a new bracket in place I headed to Homegrown Hotrods to test fit. After confirming my work, I had Aaron weld the brackets in place. He filled the bolt holes as well.
Articles-
"Refining Sierra"
Old 04-06-2019, 11:05 PM   #630
N2TRUX
Happy to be here
N2TRUX's Avatar
I headed back to my shop and spent some time cleaning up the welds and fine tune the shape of the brackets. I used a flapper disc to finesse the welds followed by sanding pads in my angle grinder.
Articles-
"Refining Sierra"
Old 04-06-2019, 11:08 PM   #631
N2TRUX
Happy to be here
N2TRUX's Avatar
With all the welds smooth I followed with a Scotch Brite pad and several coats of high build primer.
Articles-
"Refining Sierra"
Old 04-06-2019, 11:23 PM   #632
OlySezHey
OlySezHey's Avatar
That truck has a dome light, right? How 'bout matching that lens, and using something like this in all places?
https://www.autozone.com/exterior-li...light/751597_0
Any color o light you like - and a few other minor fx
Genesis 1:1 - Revelation 22:21 🙏
'72 GMC C1500 Wide Side Sierra Grande
'77 Chevy C20 CCLB (went to go get it 4/29/19!!!)
'96 Chevy K2500 Ext cab
'97 Chevy K1500 Tahoe (I gotta stop lookin' at CraigsList when I'm bored!)
'57 Chevy 6400 (coolest piece yet )
OlySezHey is offline   Reply With Quote
Old 04-07-2019, 11:09 AM   #633
N2TRUX
Happy to be here
N2TRUX's Avatar
It has a single frosted lens in the middle of the roof. I plan to add a Suburban or Astro van overhead console and update it with LED lights
Articles-
"Refining Sierra"
Old 04-07-2019, 08:54 PM   #634
N2TRUX
Happy to be here
N2TRUX's Avatar
Today I had to load an SUV and haul it to the mechanic shop for repairs. Chris tried to repair the blown spark plug threads on a Lincoln Navigator but the fix didn't hold.
After that fun trip in the rain, I got back in my shop. I started with the seat brackets. The primer got scuffed and another coat added before applying the satin black. After letting the bottom side cure I flipped them and put a few layers on the top side.
Articles-
"Refining Sierra"
Old 04-07-2019, 09:07 PM   #635
N2TRUX
Happy to be here
N2TRUX's Avatar
While the seat brackets were curing I moved on to my next project. I had been putting off working on the door panels till the appropriate time. That time had arrived.
I always start the conversion process by deep cleaning the plastic. I use Dawn and a a scrub brush followed by another round of Dawn and Scotch Brite.
Articles-
"Refining Sierra"
Old 04-07-2019, 09:15 PM   #636
N2TRUX
Happy to be here
N2TRUX's Avatar
After scrubbing both sides, I rinse and repeat . I pull out my 40 volt leaf blower to get the drying process started.
Articles-
"Refining Sierra"
Old 04-07-2019, 09:40 PM   #637
N2TRUX
Happy to be here
N2TRUX's Avatar
It's been raining here all day so I decided not to test my luck with the humidity. I put off spraying the door panels with primer and move on to the next project. I plan to run the brushed aluminum inserts in the door panels. The front pieces are reproduced, but the rear are not. I have attempted to locate quality replacements with no luck.
I decided my next best option was to restore what I have.
Articles-
"Refining Sierra"
Old 04-07-2019, 09:50 PM   #638
N2TRUX
Happy to be here
N2TRUX's Avatar
I started the process by working on the brushed aluminum finish. It had a few minor scuffs and scratches so I cleaned them as best as possible with a fresh Scotch Brite pad. With that process complete I masked the center section to protect them.
Articles-
"Refining Sierra"
Old 04-07-2019, 09:58 PM   #639
N2TRUX
Happy to be here
N2TRUX's Avatar
I used the Scotch Brite to clean the edges and remove the remains of the simulated chrome. With the surface clean, I sprayed the edges with ACE brand bright silver. It's as close to chrome as possible with paint.
Articles-
"Refining Sierra"
Old 04-09-2019, 10:11 AM   #640
N2TRUX
Happy to be here
N2TRUX's Avatar
Yesterday I made a run to College Station. On my way home I "swung by" my buddies shop in Cut and Shoot. I needed a a pair of front seat belts to rebuild and he happen to have them.
The plastics are in excellent condition so they will clean up nicely. I'll test, clean, and lube them before stripping them down for the upholstry shop to re-web them.
Articles-
"Refining Sierra"
Old 04-09-2019, 10:16 AM   #641
N2TRUX
Happy to be here
N2TRUX's Avatar
After inspecting the seat belts, I went back to work on the aluminum inserts I had started to restore. I let the bright silver cure for a day so it was safe to mask over. I taped all of the silver and shot a few coats of satin black on the perimeter stripe. After they cured I removed all of the tape a cleaned up a bit of blow through around the edges.
I will top coat the inserts with a satin clear for protection
Articles-
"Refining Sierra"
Old 04-10-2019, 09:13 AM   #642
Desert1957
Desert1957's Avatar
Too bad about the rear inserts not available. I currently need one for my truck.
No one on this site has one? hard to believe.
Desert
Desert1957 is offline   Reply With Quote
Old 04-10-2019, 09:37 AM   #643
N2TRUX
Happy to be here
N2TRUX's Avatar
I looked at all known sources as well as checked with my "Go To" squarebody experts. They all confirmed they are not reproduced.
Articles-
"Refining Sierra"
Old 04-10-2019, 11:13 AM   #644
SCOTI
SCOTI's Avatar
And...… Even if you find some NOS pieces, they won't match what you can get for the fronts from the aftermarket.
The OE chrome edge is Night/Day different vs the aftermarket version. So to keep things consistent, you'd basically be doing what you did to revitalize the used parts (or change things up like I did on the dually).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-10-2019, 11:32 AM   #645
N2TRUX
Happy to be here
N2TRUX's Avatar
You are correct. I uncovered the Cheyenne Pickup Parts dash this week, and realized the outer edge of the dash trim is black. Looks like i will be masking anf painting it as well.
Articles-
"Refining Sierra"
Old 04-12-2019, 10:13 PM   #646
N2TRUX
Happy to be here
N2TRUX's Avatar
Not much to report. I researched the SEM color I chose and found out they dont make a factory pack. I ordered a quart from my local supplier. I hope it's a good match.
I did pick up a set of rear bumper brackets that I needed. I found a great deal on a new set of brackets and grabbed them.
Articles-
"Refining Sierra"
Old 04-14-2019, 09:42 PM   #647
N2TRUX
Happy to be here
N2TRUX's Avatar
Saturday I went to Homegrown Hotrods to work on Jake. He had slowly become harder to start and keep running. The motor was running rough and any attempt to bring it above and idle caused it to die.
Aaron had pulled the hood and fenders so I had easy access to the plugs. I decided to pull one bank to see what they looked like.
As expected they were wet from fuel but not oil fouled. I found a bad plug wire and replaced the terminal.
I located and repaired a couple of vacuum leaks as well.
I decided to test fire and the results were a smoother idle. The motor still stumbled and died with minimal throttle input.
Articles-
"Refining Sierra"
Old 04-14-2019, 09:51 PM   #648
N2TRUX
Happy to be here
N2TRUX's Avatar
The P/O had installed a cheap clear plastic inline fuel filter. I noted that the fuel line fitting going into the carb was rounded off. I assumed there was no filter at the carburetor but decided to check anyway.
I discovered the filter in the carb was clogged and removed it for testing
Articles-
"Refining Sierra"
Old 04-14-2019, 09:54 PM   #649
N2TRUX
Happy to be here
N2TRUX's Avatar
I was pleasantly surprised with an easy start and quick throttle response. It seems that the small filter was the cause of my problems. I was not able to test drive but the motor ran smoother and revved quickly.
I'm almost tempted to keep this old gas hog now. Its definitely in need of a Krylon overhaul.
Articles-
"Refining Sierra"
Old 04-14-2019, 10:02 PM   #650
N2TRUX
Happy to be here
N2TRUX's Avatar
Today I went to the Classic Truck Nationals in Waxahachie. My buddy Terry Hill and a great group of truck lovers hosted a new event open to all brands of classic trucks.
It was a great show despite last minute changes to compensate for bad weather.
To justify my trip I delivered suspension parts to Mike Losh for his squarebody project. I also picked up a much needed rear bumper for Jake
Articles-
"Refining Sierra"
