Old 04-19-2019, 05:01 AM   #1
Slow Build
Slow Build's Avatar
Wiring connectors for Bose stereo.
I'm trying to figure out the correct way to wire my OEM Radio with Sirius XM with Bose system. When I bought it I tried to connect it to Sirius but it wouldn't work. Today I decided to pull the radio out to see how it was connected. It had obviously been removed before since it had phillips screws mounting the radio. After looking at it I found two connectors that could be plugged into the radio plus a male plug that would accept either connector, but the extra male and female weren't connected. The radio was connected to the female connector with less wires coming into it. Can someone tell me if the other connectors are supposed to plug together? I tried plugging the connector with more wires into the radio but it didn't have power up. I put the other connector into the radio and connected the other two connectors and the radio works that way but I still haven't been able to activate the Sirius. The only way I haven't tried is switching the more wire plug to the radio and the less to the male plug behind the radio. I've searched and found nothing about two of the same type of connector behind the radio. Can someone clue me in?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-20-2019, 10:47 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Wiring connectors for Bose stereo.
Rich
The Bose/XM radio does not have the XM receiver built into the head unit.
You will still need the XM receiver module 22692861. That # is for an 03-04 (and early 05?). If your rig had XM from the factory the receiver module can be found in the RH end of the dash. The XM modules have theftlock codes. If you buy one used it'll have to be matched to your truck with a Tech2 or MDI.
It sounds like stuff has been removed.
Assuming it had the Bose sound system stock... You may want to verify the BOSE amp, subwoofer, and other speakers were not liberated too.
The Bose Tweeters are in the A-pillar trim so those are easy to verify. Tweeters in the door panel are the mid option UQ3 6 speaker system.
Bose door grilles can be swapped in easily. I replaced my rusty door speaker grilles with some pristine black grilles rather than sandblasting and re-painting mine.
Look in my build thread for the front and rear door Bose speaker numbers and how to access them. IMHO the Bose speakers sound better than the original mid model speakers in my truck even without the associated Bose amp and sub.
You can get a complete build sheet from GM via email. Every RPO and what it means along with the date your rig rolled out the door of the assembly line. Not sure how far back they go but 2004 should not be a problem. They've provided me build sheets for my 2000 GMC C2500 and I've read claims about folks with 1991 and earlier trucks that got build sheets in this manner.
It took several days to get an answer. They sent me a PDF of the build sheet with all of the original options installed in my trucks.
When you're trying to figure out what parts you need... It's handy to have things like the brake and suspension options or the charging system option among others.
If there are any outstanding Safety Recalls associated with your VIN they will email you about them. That's likely automated once the Email is associated with a specific VIN. I got a notice about my 2000 GMC tailgate cables that I long ago replaced with stainless.
Cut and paste the To and Subject lines
---------------form email---------------
Email to: socialmedia@gm.com
Subject: Build sheet request
Hello,
I read that I could request a build sheet on the 67-72 Chevy Truck Forums.
I'm hoping you can provide me with a build sheet for My GM Light Truck.
Year, Make, Model, VIN: xxxxxxxxxxxxxxxxx
Thank you,
My Name
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
