High zinc oils
I have been using amsoil zrod for a few yrs in my 70 challenger with 512 stroker,it seems good and stays clean longer then others i have tried such as joe gibbs or vr1.What are you guys using in your flat tappet engines?
I use amsoil in all 6 of my vehicles front to back diesel and gas |
Re: High zinc oils
Exact same thing here. My brother uses Amsoil signature 20w-50 in his 1970 C10 350 with 100k+ miles on original build and noticed on the bottle it says includes zinc.
Re: High zinc oils
i believe the zrod 10/30 has 1200 ppm zinc plus other additives for anti corrosion,also higher phosphorus
Re: High zinc oils
I just changed mine for the first time since I have owned it. 283 Canister type
Used Penn Grade, formerly called Brad Penn after Bradford Pa. The old Kendall GT plant...Has plenty of zinc. I used 10w 30... I have used it in my 67 427 Sting Ray 20w 50 mix. So far so good !
1967 GMC 3/4 ton custom. 283 4 speed unrestored |
Re: High zinc oils
Joe Gibbs (Driven) oil and Torco Oil. I really like the Joe Gibbs. I run the 20w-50 in my 454.
![]() Join Date: Feb 2002
Re: High zinc oils
Valvoline 30 weight Racing p/n 223. Now branded VR1.
![]() Join Date: Nov 2018
Re: High zinc oils
I run Pennzoil and a bottle of Lucas Zinc additive, if I need to top it off before scheduled oil/filter change I add Lucas Oil Stabilizer.
Re: High zinc oils
Brad Penn
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
![]() Join Date: Jul 2015
Re: High zinc oils
VR 1 gets my vote.
Re: High zinc oils
Re: High zinc oils
When it comes down to high zinc motor oil. Read the data sheets from the motor oil and pick one with a decent zinc content that also has the best price for you and dont look back. All this advertising has made people believe the oil in a bottle of valvoline VR1 is so much different than the oil in the bottle of brad penn it will make or break your engine. Simply not true.
Also, 540 Rats oil testing methods have been questioned and debunked for years now and do not relate at all to the actual conditions of an operating engine, take those tests with a grain of salt and move on. |
Re: High zinc oils
You might find this oil guideline interesting:
http://www.pqiamerica.com/apiserviceclass.htm |
![]() Join Date: Dec 2013
Re: High zinc oils
Castrol 20/50 and STP oil treatment . This is all I've ever used and never had an oil related failure in a first gen small block or L6. About $30.00 for an oil/filter change
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
