![]() Join Date: Jan 2018
WS Washer Delete Feasibility
I am looking to shave my firewall when I convert over to Vintage Air. With this said, I would like to shave the space where the WS Washer hoses run as well. To add to this, I put on a universal WS washer and the first time I used it, it blew my intermittent wiper module.
My question is how much of a pain is it to run no WS Washer on a daily driver?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
![]() Join Date: Dec 2013
Re: WS Washer Delete Feasibility
There's no need to loose your washer function , You can feed the washer squirters by running the hoses from INSIDE the cab into the cowl space . I shaved the complete gutter rail off and smoothed the firewall and The washer plumbing will run from inside the cab ,under the dash with the washer reservoir still in the engine compartment where it was stock .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I have a radical idea!
These trucks had a WS washer????😂😉
I have put thousands and thousands of miles in probably 2 dozen of these trucks and I’ve never had one that worked (in fairness I never even checked in most of them), so for me at least, that’s a non issue.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
