04-09-2019, 02:23 AM | #1 |
Last project 1964 C10
Here is a run down of my 1964 C-10 project. I just turned 60 yrs old and I think this will be my last build..so I maybe dump a bit more effort into it.
I started with a short bed frame I found on CL for $125.00 and added a Porterbuild suspension kit , 496 big block with FiTech EFI and Jones Racing pulley system , Turbo 400 Gear Vendors Overdrive and a fresh 12 bolt Posi. I swapped in a Big back window and every panel is brand new..
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
04-09-2019, 02:25 AM | #2 |
Re: Last project 1964 C10
04-09-2019, 02:28 AM | #3 |
I took it to one painter and he made a mess of it so its now at a new shop..
04-09-2019, 02:31 AM | #4 |
This is fresh out of paint at the new shop...Im not sure how nice it is these photos were send to me. I am in the Philippines right now with the wife..
04-09-2019, 07:17 PM | #5 |
looks good, keep up the work
04-10-2019, 01:21 AM | #6 |
60-66 Nut
That looks awesome!
04-10-2019, 06:52 AM | #7 |
Thank you...I did use your rear disk brake adapters with Wilwood d-52's
04-10-2019, 10:31 AM | #8 |
Glad to see you got the truck together. Looks really good.
04-10-2019, 07:48 PM | #9 |
well . it's taken the painters a year to get color on it....not all together yet
04-10-2019, 08:17 PM | #10 |
I really like what you are doing with this one. These trucks look amazing in black.
What size wheels and tires is that? |
04-13-2019, 04:05 PM | #11 |
That looks incredible, well done.
04-14-2019, 10:16 AM | #12 |
It looks great! I hope you don't mind picking your brain a little. What kind of header did you use? Did you move the engine forward and what about valve cover clearance?
I am just about to start on my 65 swb I have all the parts to start just need a few more things headers being one of them. |
04-16-2019, 06:12 PM | #13 |
Nice.... Old school build using new tech. I like it!
04-27-2019, 05:19 AM | #14 |
275-70-15 on 15x8,5 rims in rear.
04-27-2019, 05:24 AM | #15 | |
04-27-2019, 06:57 AM | #16 |
67-72 parts collector,…
Awesome build.
Very cool everything!
