04-25-2019, 12:02 AM | #701 |
Happy to be here
Re: "Crewcab Jake" the 84 to 74 conversion
While the box was curing I went to work on the back of the bumper. Yeah I know its a bit anal, but I really hate how the back side of the bumper looks after it's been in the weather. The thin areas of plating quickly discolor and are prone to rust.
To prevent that from happening I clean the surface thoroughly and scuff it down with a fresh pad of green Scotch Brite.
04-25-2019, 12:08 AM | #702 |
Happy to be here
After another wipe down and a blast of air to clean up debris. This was followed by a few layers of primer. I'll let this cure over night before scuffing again
04-25-2019, 10:47 AM | #703 | |
Happy to be here
The wheel stand was my first attempt. I will have to check the length since its been a while since I built it.
04-25-2019, 10:38 PM | #704 |
Happy to be here
Tonight Chris came over and gave me a hand hanging the rear bumper. I have never had a rear bumper installed since I owned the truck but I had a feeling it might not be a bolt on deal.
04-25-2019, 10:48 PM | #705 |
Happy to be here
Due to the short bed conversion the brackets didn't exactly fall in to place. Its positioned a bit to high, and needs to tuck in but the leaf spring hanger are preventing that. We moved it around a bit and locked the brackets down
04-25-2019, 10:55 PM | #706 |
Happy to be here
We hung the bumper and played with the position a bit more. We got it as close as we could for now. When we get back from C10 Nationals the frame rails will be stripped again to hand the Ridetech 4 link with coilover. We will make necessary adjustments and get the position correct at that point.
04-25-2019, 11:01 PM | #707 |
Happy to be here
I pulled the bumper off of the brackets and set it aside. I scuffed the brackets and hit them with a couple coats of Krylon to cover our install scratches.
I flipped the bumper over and scuffed it down again. It got several coats of bright aluminum paint and left to dry.
04-27-2019, 07:33 PM | #708 | |
Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
04-27-2019, 10:51 PM | #709 |
Happy to be here
It's been a hectic week so let's get caught up. I needed a set of bumper bolts to hang the bumper, so I ordered a set from Summit Racing. Turns out they were wrong so I bought a set locally at Outback Truck parts.
They had what I needed, but I wasnt satisfied with the full finish. I spent some time polish the heads. While I was at it I did the same for the plate box bolts.
04-27-2019, 10:56 PM | #710 |
Happy to be here
With the bolt heads polished I could do final assembly on the bumper. I bolted the license plate to the box, then put the box in place with the new bolts.
04-27-2019, 11:05 PM | #711 |
Happy to be here
Chris came by and helped me hang the bumper. Once we got it squarely in place I installed one of my tailgate bands to see how it looked. I started with the narrow Cheyenne band to see if I liked it now that the bumper was on.
04-27-2019, 11:11 PM | #712 |
Happy to be here
It seemed a bit to plain with the sidemolding to enhance it. I decided to put the early Silverado band on see which one I liked best.
04-27-2019, 11:16 PM | #713 |
Happy to be here
So I'm still undecided which band to run for this show. No matter what, the final decision wont be made till I put the trim on. Until then which one do you prefer?
Top or bottom?
04-27-2019, 11:19 PM | #714 |
Happy to be here
Another view
04-28-2019, 12:13 AM | #715 |
The large insert overpowers the area. Small band is subtle.
04-28-2019, 07:39 AM | #716 |
I like the narrow band. It’s different since you never see those.
04-28-2019, 08:26 AM | #717 |
The ol' school look of the narrow band looks better imo.
Genesis 1:1 - Revelation 22:21 🙏 '72 GMC C1500 Wide Side Sierra Grande '77 Chevy C20 CCLB (went to go get it 4/29/19!!!) '96 Chevy K2500 Ext cab '97 Chevy K1500 Tahoe (I gotta stop lookin' at CraigsList when I'm bored!) '57 Chevy 6400 (coolest piece yet ) |
04-28-2019, 10:33 PM | #718 |
Happy to be here
I guess y'all will have to wait and see which one stays. Keep in mind the final decision wont be maid till the sidemolding goes on.
04-28-2019, 10:41 PM | #719 |
Happy to be here
Wow, what a crazy weekend. We bounced back and forth between several projects.
Saturday morning I went to see Jaime Villalobos at Cypress Auto Interiors to pick up the inserts he had covered for me
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-29-2019 at 09:39 AM. |
04-28-2019, 10:50 PM | #720 |
Happy to be here
After leaving with my newly covered inserts I headed home to work on the plastic pieces. I gave each piece a thorough scrubbing with soapy water, rinsed and repeated. Its tedious work but is truly necessary to ensure a clean surface. I gave them a blow dry with my leaf blower and layed them in the sun to finish the process.
04-28-2019, 10:54 PM | #721 |
Happy to be here
Once all the pieces dried, I sprayed the back and front with SEM primer. I gave each piece two wet coats and laid them on my trailer to bake in the sun. Unfortunately it got dark and I didn't get pics before bringing them inside.
04-28-2019, 11:05 PM | #722 |
Happy to be here
Between coats of primer I opened up a shipment I had received from Brothers Truck Parts. There were a few final pieces of the interior puzzle that I desperately needed to complete the package.
One of those parts were a new a/c vent.
04-28-2019, 11:19 PM | #723 |
Those aluminum pieces tie in that smaller tailgate insert.
04-28-2019, 11:21 PM | #724 |
Happy to be here
You might ask why one would get a brand new part, and immediately take it apart? Especially when you consider these parts are the very well made.
I have found that there is a minor modification that can be made to greatly improve the function of the a/c vents. To compound the foam disc that's designed to keep the vent aimed where you set it is too soft and too thin to be effective. I can't do anything about the vent location, but I do have a cure for the vents staying where you direct them to.
04-28-2019, 11:30 PM | #725 |
Happy to be here
I found a fiber disc that's used as a furniture glide. I shopped till I located a size that was very close to the foam washer in the vent. Gently peel the old one off. Dont worry about the adhesive backing left behind unless it balls up.
I use a pencil tip soldering iron to burn a hole in the middle that's big enough to fit over the spindle.
