01-29-2019, 11:48 AM | #176 |
Re: Another way to skin the cat; the High Torque 292 LS swap
01-29-2019, 12:27 PM | #177 |
I’m a self taught gearhead. So, I know the injector bottoms out in the intake, then I slightly brought it back ever so slightly. So the end cap comes off and the injector, then should protrude through the base of the intake? Thanks Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
01-29-2019, 12:50 PM | #178 |
yep Jonathon...you removed the black plastic end...at least that's what you told me to do on mine....haha
01-29-2019, 03:30 PM | #179 | |
Thanks for the reminder! |
01-29-2019, 04:13 PM | #180 |
I appreciate all the help!! Thanks Mike
01-30-2019, 12:40 AM | #181 |
Wow, I really enjoyed reading this. Style and taste are individual, but combined with ingenuity, the appeal is universal. I hope to see more on this truck. Thanks for sharing.
04-14-2019, 10:56 PM | #182 |
60-66 Nut
I really like what you did with your truck build.....nice job
04-24-2019, 02:11 AM | #183 |
Joining the swap community but the simplicity and fabrication is top notch.
Tell us your really a 🚀 scientist and if not your work and detail is worthy of one. Thanks for sharing. My swap may never match up but the bar has been set. Next read is lsnova. Thanks again
72 GMC Sierra 2500 |
04-24-2019, 10:30 AM | #184 |
LS1Nova your PM box is full
I have a question for you!
04-26-2019, 12:50 AM | #185 | ||
05-03-2019, 12:28 PM | #186 |
Wow! Beautiful work. The vision, the fab, and the pics. Everything top notch.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
05-08-2019, 02:40 PM | #187 |
What exhaust manifolds did you use?
1965 c/10 swb 1969 c/10 lwb |
05-08-2019, 04:28 PM | #188 |
05-09-2019, 12:20 AM | #189 |
A guy with a truck
Just wanted you to know this thread is a giver. I’ve used it twice in the last week, once plumbing fuel lines and once cutting radiator hoses. Thanks!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-09-2019, 01:10 AM | #190 |
So true!!!!!!
05-09-2019, 02:04 PM | #191 | |
Just a dang good dude all around & I'm lucky to be able to call him a friend. |
05-10-2019, 10:30 AM | #192 | |
Thanks! I don't think there are many of us who do everything to our trucks by ourselves. I know my projects wouldn't turn out as well as they do nor be finished as quickly if I didn't have help from my friends. And, of course, that includes all the side projects I send your way! |
07-04-2022, 07:29 PM | #193 |
Is there a disadvantage of just converting a 71-72 style fuel sending unit to a return/feed system? I've noticed a few guys adding an extra inlet/outlet to the tank. I was going to convert a 71-72 over... but I'm second guessing myself now.
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
07-05-2022, 03:50 PM | #194 | |
I'm sure the stock sender could be modified to work, but I went with what I thought was an easier/better alternative for me. |
07-05-2022, 04:00 PM | #195 |
Posted via Mobile Device |
12-23-2022, 07:55 PM | #196 |
Hey, looking to do a similar swap and my issue is leg room in the cab. It looks like you had plenty of room in that area behind the driver's side cylinder head to mount your coils. If I didn't do that, would I be able to push that area of the firewall, where the throttle pedal attaches, forward an inch or two without interfering with the back of the engine? It almost looks like the firewall could be flush all the way across behind the engine in your photos.
"A man's got to know his limitations" 1969 Chevy C20 Camper Special 1968 Chevy C-10 short/fleet 1970 GMC Jimmy 4x4 (SOLD) |
