Old 05-28-2019, 05:46 PM   #1
Livemeyer
Livemeyer's Avatar
Q's about installing 80mil sound deadener
Got my Noico 80mil butyl automotive sound deadener, roller, tape, etc. and am prepping the inside roof of the cab. Scraped off all the old cloth-like material (is it fiberglass?) but in places it wasn't, there's some surface rust. I'm working to remove the surface rust, and here's the question: should I just put this stuff straight onto the bare steel, or should I apply a rust-inhibiting paint or primer first, or something else? I figure the sound deadener might affix itself better to the bare steel, but am unsure if it's best to leave the steel in an untreated condition.
Livemeyer is offline   Reply With Quote
Old 05-28-2019, 06:01 PM   #2
mr48chev
mr48chev's Avatar
Re: Q's about installing 80mil sound deadener
I'd put on rust inhibiting/stabilizing paint just as a precaution. Anything you can do to stop or slow down rust is going to help the truck last a lot longer.
My ongoing truck projects:
Old 05-28-2019, 08:21 PM   #3
Black_Sheep
Black_Sheep's Avatar
I believe the sound deadened will adhere better on a clean, painted surface
Black_Sheep is offline   Reply With Quote
Old 05-28-2019, 10:00 PM   #4
Livemeyer
Livemeyer's Avatar
Sounds like that is prevailing opinion. As long as the sound deadener can adhere to it, that's the plan.
Old 05-28-2019, 11:01 PM   #5
mr48chev
mr48chev's Avatar
I've never tried rust converters or even the paints that say they will stop rust but getting all the loose stuff off and using a product that says it will convert/stop the rust seems to make a lot of sense.
Let us know how that particular sound deadener works out. We are always up for valid reports on how sound deadener or heat blocking products actually work.
Old 05-29-2019, 12:51 PM   #6
Driver_WT
Driver_WT's Avatar
I have used Rust Bullet on previous builds. Used it on a rear axle housing that was 20 years old and rusty - in the last 10 years, no rust has come through the Rust Bullet coating.
I have also used POR15, but that project is only about a year old, so no long term experience to report.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 05-29-2019, 05:21 PM   #7
_Ogre
_Ogre's Avatar
fyi once installed the original rubber trim won't fit
i used black door edge molding to finish off my 58 headliner
sound deadener covered in ultrasuede
shop air compressor timer
Old 05-29-2019, 06:05 PM   #8
Driver_WT
Driver_WT's Avatar
Very nice.
Old 05-30-2019, 01:25 PM   #9
_Ogre
_Ogre's Avatar
door edge trim also comes in chrome if your a chrome type of guy
Old 06-03-2019, 05:48 AM   #10
Livemeyer
Livemeyer's Avatar
I think what you've done there looks awesome, but your mention of the original rubber trim confuses me. I don't think I'm dealing with any rubber trim on a '51. It's just two cardboard strips with a center frame and rear frame with screws.
Old 06-05-2019, 02:21 PM   #11
Ironworking
Ironworking's Avatar
One of, if not the very best heat blocker is 1/4" thick cork board.
Ironworking is offline   Reply With Quote
interior, noise dampening, rust, sound deadener
