Old 06-02-2019, 03:37 PM   #1
wazzabie
Can a later GM door work with the earlier door panels (73-78)?
Can a later door after 81 work with the earlier door panels from (73-78)?
wazzabie is offline   Reply With Quote
Old 06-02-2019, 05:38 PM   #2
TKCR
TKCR's Avatar
Re: Can a later GM door work with the earlier door panels (73-78)?
Yep, I believe so
Old 06-02-2019, 07:25 PM   #3
WyattTX
73-76 have unique inner skins. The plastic interior parts look different in the 77-91 door skins (77-80, and 81-91 styles), but everything should interchange. If you want to put a 73-76 panel on a 77-91 door, you will have to cut the inner skin out, and weld a 73-76 skin in its place.
WyattTX is offline   Reply With Quote
Old 06-03-2019, 08:33 PM   #4
Pontiac1976
Pontiac1976's Avatar
This may help
http://bowtieguy.proboards.com/threa...-87-break-fits
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-03-2019, 08:48 PM   #5
TKCR
TKCR's Avatar
Originally Posted by Pontiac1976 View Post
That’s some good info! Thanks for posting that Pontiac1976. A lot of stuff I didn’t even know.
Old 06-03-2019, 10:35 PM   #6
cadillac_al
Dang, I guess I have to keep patching my 76 doors because it's too much hassle to change everything.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-04-2019, 12:31 AM   #7
WyattTX
A little off topic, but can the different style dashes, guage clusters, and dash bezels be interchanged between all years?
Old 06-04-2019, 02:41 AM   #8
wazzabie
there were many changes and options over the years. oil gauge elec vs mechanical, tach vs no tach, changes in dial face, in 90?/ 91 there is the elec spedo
Old 06-04-2019, 02:45 AM   #9
wazzabie
I've been looking for this for a long time. thank you!
Old 06-04-2019, 10:07 AM   #10
MJN
MJN's Avatar
The info at this link may help answer some of your questions regarding the gauges. https://www.73-87.com/7387garage/int...achometers.htm Bezels will interchange-although not always look correct. Dash pads changed in '78 to allow for a cut out area for the VIN plate mounted by the windshield. They are backward compatible though- something to keep in mind if you have a '78 to '80 though, you will need the cut out to keep your VIN visible.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-04-2019, 12:02 PM   #11
WyattTX
Thanks. From a electronics perspective, it looks like you. Need to be careful with swapping clusters.
