Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-16-2019, 10:35 AM   #1
MikeB
MikeB's Avatar
Dash lamps for 69 truck
Would like to hear your suggestions for dash lamps. RockAuto shows the following, among several others:
Wagner #1445 -- 1.94 watts
Wagner #1816 -- 4.29 watts
They also list LL (long life) versions of the above with the same wattage specs.
Obvious I'd want the higher wattage bulbs, but are those specs correct?
FYI, AC-Delco has a L1445, but they don't show wattage.
Also, I want to get a few bulb sockets. Will I need both 1/2" and 5/8"?
The truck is at my son's house 1500 miles away, so I can't pull the instrument panel to check it.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-18-2019, 12:57 PM   #2
MikeB
MikeB's Avatar
Re: Dash lamps for 69 truck
Bump
Mike
Old 04-18-2019, 08:09 PM   #3
dmjlambert
dmjlambert's Avatar
The lamps are 194 wedge base lamps. If you like them brighter than standard, a 168 bulb is the brighter version.
Old 04-19-2019, 01:14 PM   #4
MikeB
MikeB's Avatar
Thanks. Same as my 82 truck.
1816 and 1455 must be the latest bulb numbers.
Do you know if the sockets are 1/2" or 5/8" diameter?
Mike
Old 04-19-2019, 06:49 PM   #5
dmjlambert
dmjlambert's Avatar
5/8 according to this listing
https://www.classicindustries.com/pr...ts/cx1807.html
I don't think you can be 100% sure until you walk up to the truck. I have seen mention on this forum about people finding completely different bulb holders and bulbs in their truck's instrument cluster.
Old 06-04-2019, 11:13 PM   #6
PAWS 72
PAWS 72's Avatar
I've got 15155, im thinking, in mine. They are pretty bright. also paint the cluster housing and the back of the black shield white or silver. I painted mine silver.
PAWS 72 is offline   Reply With Quote
Old 06-05-2019, 07:40 AM   #7
MikeB
MikeB's Avatar
Thanks guys. I was able to reach under the dash and replace three 194 bulbs (one bad, two others probably on their last legs) with Sylvania 168LL bulbs. The last time I replaced a bulb in the truck was in the late 80s/early 90s, and some of those that I replaced this week may actually be original equipment!
The 168s are still not very bright, so next trip I may pull the panel and "brighten up" the inside of the bezel. I did something similar on my 82 truck. Instead of paint, I used aluminum HVAC tape. It made a noticeable difference.
On a related note, just replacing the OE wiring harness, fuse panel, and most connectors on my 82 increased the voltage to the instrument panel by nearly 2 volts (!) under load. Same is true for the headlights, so no headlight relays are needed!
Mike
Old 06-05-2019, 09:31 PM   #8
PAWS 72
PAWS 72's Avatar
I was wrong on numbers. They are 17177.
