Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-07-2019, 12:35 PM   #26
The1960APE
The1960APE's Avatar
Re: 1971 2wd Great Motor Carriage..... Sprucing up my Jimmy!
its getting closer..
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 06-07-2019, 12:39 PM   #27
The1960APE
The1960APE's Avatar
I'm having a hard time uploading pics, I received the Restomod Air kit. I am really impressed with the kit, the quality seems to be much better than the Old Aire products or Vintage Air kits I have used
Old 06-07-2019, 12:47 PM   #28
The1960APE
The1960APE's Avatar
Closer and Closer. Some of the audio items arrived today, I have always a good stereo but I don't make it a focal point of the vehicle, I like for it to be hidden and very tasteful! Im not looking to shake the neighbors, just for my own enjoyment while driving!
Old 06-07-2019, 12:50 PM   #29
The1960APE
The1960APE's Avatar
The engine is about done, we are anticipating 750-800 RWHP, Transmission is ready, we are just about ready to paint it!, the frame goes off the be blasted next week!
Old 06-07-2019, 02:51 PM   #30
raggedjim
raggedjim's Avatar
Great work on this jimmy. Was the body pretty good or did you have some repair work to do?
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 06-07-2019, 03:13 PM   #31
lks dcvn
lks dcvn's Avatar
Hey - I just pinged you on IG the other day about your audio set up. Looking forward to seeing how it all comes together! Awesome Jimmy.
lks dcvn is offline   Reply With Quote
Old 06-07-2019, 04:27 PM   #32
The1960APE
The1960APE's Avatar
Good luck, Rg
It was pretty good, there was an issue at the top of the windshield frame! Also a couple spots in the top of the bed rails at the rear, we also found a couple of issues underneath but nothing to bad!
Old 06-07-2019, 04:31 PM   #33
The1960APE
The1960APE's Avatar
I am a bit interested also, since its mini tubbed the entire bed will be upholstered. Right now the plan is to have 2 10s firing to the rear at a 30-45 degree angle, 2 8s firing forward behind the rear seats at the same angle, the rear seat would be in between the 8's, then the 6.5s in the kick panel, more than likely the highs in the kick panel and the 3.5s in the dash, the front setup will be running full active! The dash unit is the Avic 8400, we wanted the 8500 but its not out yet! we ordered a processor that I can tune the crossover and gains from my phone!
Old 06-07-2019, 09:12 PM   #34
DPowers
One foot in front of the other
DPowers's Avatar
Looking good Mark.
DPowers is offline   Reply With Quote
Old 06-10-2019, 12:37 PM   #35
raggedjim
raggedjim's Avatar
Originally Posted by The1960APE View Post
...there was an issue at the top of the windshield frame!
I would have been more surprised if there hadn't been! I had to cut out the top part of mine and weld in a replacement.
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
