Old 06-07-2019, 03:24 PM   #1
jwhotrod
My 55.2 truck build in Illinois
I am starting my build thread now. Its a 55 chevy that I bought from a friend way back in 2000 or so. Drug it out of storage last fall and started in.
was looking for suspension options, (i have put 5 or 6 mustang ll front ends in streetrods) and I love Fatmans stuff but wanted different here. So i found QB Racings build in New Zealand on youtube which lead me to this forum.
So i ended up ordering the C4 conversion kit from flatout-engineering and bought the suspension from a 1990 corvette, Dana 44 rearend 3:45 posi gear.
So off i go.working with the chassis right now, cab and box are that fabled California ruff (no rust) pictures below.
jwhotrod is offline   Reply With Quote
Old 06-07-2019, 03:29 PM   #2
mongocanfly
mongocanfly's Avatar
Re: My 55.2 truck build in Illinois
That's gonna be sweet...flatout makes some nice stuff...I've got their front crossmember for mine
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-07-2019, 11:37 PM   #3
oldman3
oldman3's Avatar
Nice work...Jim
oldman3 is offline   Reply With Quote
Old 06-08-2019, 10:15 AM   #4
Rickysnickers
That looks nice!
Old 06-08-2019, 12:50 PM   #5
dug224
dug224's Avatar
Great craftsmanship. Subscribed!!
dug224 is offline   Reply With Quote
Old 06-09-2019, 10:24 PM   #6
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Cool, I'm in!
ChuckDriver is offline   Reply With Quote
Old 06-10-2019, 11:43 AM   #7
jwhotrod
I'm posting some progress photos. One of the things I did was when I notched the frame rails for the rack and pinion box it looked weak and a probable hinge point so I added some bridging to the crossmembers to compensate.
Old 06-10-2019, 12:37 PM   #8
Kevin_C
Subscribed. Nice looking build. I'm going the same direction. My flat out kit arrives tomorrow!
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 06-10-2019, 10:44 PM   #9
svr
svr's Avatar
JW I’ve got a question on your rear spring, it looks like you have a multi leaf spring in place of the corvette single fiber glass spring. Im using the fiber spring on mine from an ‘88, just wondering if yours came that way or if this is your mod. Curious, thanks
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 06-11-2019, 04:38 AM   #10
bobinbc
bobinbc's Avatar
I was wondering about the rear spring too and then I realized that it's a picture of a different chassis (mid 30's Ford?)
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 06-11-2019, 10:38 AM   #11
jwhotrod
I must apologize, when I was grabbing photos to post, I grabbed a picture of a 32 ford chassis that a friend is building in my shop. it is a 32 Ford 3 window coupe, the body is out for paint right now. but if you look at the close up side shot of my frame you will see that the flatout engineering stuff I that I used is setup to use coil over or shockwaves instead of the mono leaf the corvette used. my plan is to use shockwaves because I am not at all fond of coilovers. No I will not lay this on the ground at a car show. If you do that, someplace at 70 mph you lose air in the suspension you wont like the results. I have built bump stops into the chassis to make sure if we loose the suspension, we can still limp to safety without damaging anything.
Old 06-11-2019, 10:05 PM   #12
svr
svr's Avatar
Guess i need to broaden my vision, missed everything else
