06-16-2019, 11:06 AM | #1 |
Old member
Need help please
I bought some LED tail lights from a member and had trouble with them this past week on the tour. One row has quit working so I like to see if he can fix them. They are less than 2 year's old. All I have and can remember is his last name and where he is from.
Hinerman from Broomfield Co. If you know his member's name please post it so I can message him please. Thanks
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-16-2019, 02:21 PM | #2 |
Re: Need help please
If it does not work out to get in touch with him, it could be something minor like a solder joint on the back that needs repair or one of those resistors that failed.
06-17-2019, 07:01 AM | #3 |
Old member
That's what I'm thinking but where do you start and how would I replace the things them?
06-17-2019, 07:24 AM | #4 |
This guy sells them.
If he not the one you got them from, Maybe he could help you. http://67-72chevytrucks.com/vboard/s...ed+tail+lights .
06-17-2019, 05:18 PM | #5 | |
Old member
06-17-2019, 09:05 PM | #6 |
LED's need a resistor to keep the current (amps) from burning out the device. From your picture it looks like there are several resistors clumped together near the center. Maybe each feeding a group of bulbs.
Without any thing hooked up, you might used a dvom to check each resistor for an 'open'. |
06-18-2019, 05:27 PM | #7 |
Old member
Rob is making good on the lights! He is making me a new set. They will be brighter and longer lasting than before!
07-08-2019, 04:22 PM | #8 |
Old member
Update
Got a hold of Rob on Instagram and he has mailed me a new set for 1/2 price. Very pleased with him and his customer service.
