Old 06-17-2019, 10:46 AM   #1
sircrunch
engine size emblems below front side marker lens, what is correct?
Looking around at pictures all over the internet, I'm seeing some trucks with the "8-350" emblems for instance, under the front side marker. But most pictures I see, the truck does not have these. And I can't find any rhyme or reason (year, trim level, engine type etc) as to why these truck have or don't have the emblem. What is correct? with or without? I have a 70 c10 short stepside that has a 350 in it now. It originally was a 6 cyl I think. It does not have the holes in the fender for these emblems. But I found some new emblems at the swap meet and I'm not sure if I wanna use them or not.
sircrunch is offline   Reply With Quote
Old 06-17-2019, 12:39 PM   #2
randy500
Re: engine size emblems below front side marker lens, what is correct?
If it came with an optional engine such as 292, 350 or 396/400 it got the corresponding emblem.
randy500 is offline   Reply With Quote
Old 06-17-2019, 02:36 PM   #3
sircrunch
so... EVERYTHING except the base engine got an engine displacement emblem on the front fender? and also, what determined whether the emblem was placed under the side marker or on the fender behind the front wheel?
Old 06-17-2019, 04:28 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
Correct - only optional engines had badges. Location was determined by year. Under the emblem for 69-70 and under the marker light for 71-72.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-17-2019, 05:33 PM   #5
basketcase
basketcase's Avatar
My '69 C10 short step spid doesn't say which engine and there are no engine size badges on it. Original paint truck. It does callout a 3 speed automatic. The guy I bought it from said it didn't have an engine when he bought it but the previous owner said it was a 307 turbo 400. It has an original V8 wiring harness. So was the 307 considered a standard V8 if you ordered a V8 truck?
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 06-17-2019, 05:54 PM   #6
jocko
jocko's Avatar
Yes, if your VIN starts CE or CCE, as opposed to CS or CCS and there is no engine option on the SPID, it was born with a 307.
Old 06-17-2019, 06:20 PM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
How you guys keep all this info. straight in your head is beyond me......Simple trucks, yet so many variables.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-17-2019, 07:55 PM   #8
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Yes, and we seem are always finding out new things about the trucks. Reminds me of an old saying " When you think you have all the answers its because you haven't heard all the questions". There are pretty much no absolutes with these trucks.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-17-2019, 10:11 PM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
This is correct...On a side note, Gmc didn't have an emblem for engine size. And for more confusion, I think 68-70 4x4s had a 4 wheel drive emblem under the front marker light.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-17-2019, 10:21 PM   #10
57rookie
Agreed. I have a GMC now and a previous 67 and the GMC never had an engine emblem. Does not mean a guy cant add one if they wish. I left mine without the badging. I did add all the other optional outside trim though.
57rookie is offline   Reply With Quote
Old 06-17-2019, 10:33 PM   #11
basketcase
basketcase's Avatar
Thanks. I sort of thought that was the case.
Tom
Old 06-17-2019, 11:15 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Our 68 begin with with CE and has a 327 in the spid or is the CE vin for 69 and up?
Old 06-18-2019, 09:22 AM   #13
palallin
CE (E = eight) means V8 for all our years; CS (S = six) means 6 cylinder.
Base V8 in '67 = 283; base V8 '68 - '70 (at least, I think through '72) = 307
A '68 with a 327 should have a code on the SPID.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 06-18-2019, 10:10 AM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
I mis read it. Unless it's called out it's born with a 307
Old 06-18-2019, 06:39 PM   #15
71CHEVYSHORTBED402
True story. Top of my head there's a half dozen "is", "because" and "must be". None are true.
Tony
Old 06-18-2019, 07:53 PM   #16
Steve Cole
A lot of great info here! Where would the engine badges be for a 67-68 with a optional engine?
Steve Cole is offline   Reply With Quote
Old 06-18-2019, 11:25 PM   #17
too much stuff
Roadtrip!
67-68 didn't get engine badges. The c-40 and up may have had 366 or 427 on the side of the hood.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 06-19-2019, 09:12 AM   #18
old51sedan
old51sedan's Avatar
For an example, my 1969 came from the factory as a 250 six cylinder. On the SPID sheet the Vin number has the letters CE which means it was born with the 250 six cylinder. I'm in the process of removing the 250 and installing 292. I have already drilled the holes below the C/10 emblem to install the 292 emblems. This is the same place that they were on the new 1969 that I bought in the fall of 1968. If it had came from the factory with the 292 it would have listed the engine as an option on the SPID, and the emblems would have been below the C/10 emblem as the one. I bought new.
old51sedan is offline   Reply With Quote
Old 06-19-2019, 10:41 PM   #19
too much stuff
Roadtrip!
CE would be an 8 cyl. CS would be a 6.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 06-20-2019, 04:51 PM   #20
old51sedan
old51sedan's Avatar
Too Much Stuff,
You are absolutely correct about the CE and the CS, and I know that. I guess it pays to proof read our own words once in a while. Thank you for the correction, I sure wouldn't want to miss lead anyone.
