Old 06-17-2019, 09:38 PM   #1
Justin1983
67 Chevy c20 250 thermostat housing leak
I have a stock 67 Chevy truck 250. I tried fel-pro gasket twice and I also tried black rtv . I lightly Sanded and made sure everything is clean and smooth. I'm using the blue composit fel-pro gasket. Both times I didn't use and gasket sealer ... I cant get nothing to work it's a light leak. Any ideas or part numbers would be great guys thanks. The thermostat housing where it bolts to the head...
Justin1983 is offline   Reply With Quote
Old 06-17-2019, 11:02 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 67 Chevy c20 250 thermostat housing leak
Are you sure it isn't cracked? I would try another housing. How does the flange on the head look?
LockDoc
Leon
Old 06-18-2019, 07:27 AM   #3
Justin1983
Don't see any cracking. Flange? It's just a flat surface that it bolts 2 on the head
Old 06-18-2019, 01:29 PM   #4
LockDoc
LockDoc's Avatar
Just different terminology, we are talking about the same thing..... It could also be cracked. You obviously have something else going on besides a leaking gasket.
LockDoc
Leon
Old 06-18-2019, 05:50 PM   #5
michael bustamante
michael bustamante's Avatar
I think I have a spare 250 t stat housing at home, ill dbl chk for you in case you need it
1967custom
michael bustamante is offline   Reply With Quote
Old 06-20-2019, 10:22 AM   #6
Justin1983
Could I use k seal to fix this
Old 06-20-2019, 01:20 PM   #7
Justin1983
All they have are aluminum thermostat housing for these ... thoughts?
Old 06-23-2019, 12:59 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
I think I have a T-Stat housing top on my 292 from an earlier Toyota L6 engine [the kind they copied from early '50s Chevy engines and used in Landcruisers.]
It's steel or cast iron. Has 1/2'' plug for a temp probe, too.
