06-30-2014, 04:55 PM | #1 |
"Junkyard Dog"
What color is this 67 C10 seat?
I'm trying to figure out what color this seat is so I can get a new covers. Is it Aqua or metallic green? Those seem to be the two choices that the after market companies offer. It is out of a 67 C10 base model truck. The interior color is light green metallic and the outside is the same as the doors in the pics. Pics courtesy of GCncsuHD. Thanks in advance for any help, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 06-30-2014 at 05:39 PM. |
06-30-2014, 05:26 PM | #2 |
Re: What color is this 67 C10 seat?
It is Turqouise
06-30-2014, 05:57 PM | #3 |
light green? truck doors appear to be light green...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
07-01-2014, 06:50 PM | #4 |
I'm going through the same thing with my '67, same colors in and out except mine has the Custom interior, so slightly different seat but same color.
I have not had much luck with matching it up. I got samples from The Filling Station and it was almost an exact match for Aqua. I ordered the cover and after a month when I called to check status they told me it was discontinued. I see that GMCPauls also has the same color selection but no samples available. I went ahead and ordered Aqua again-- taking a chance-- but it will be about 8 weeks before I see anything they tell me. Short answer-- I think it is called Aqua in the aftermarket. Adam |
07-01-2014, 07:46 PM | #5 |
I had a 67 Bel Air w/ similar interior, exterior was close, paint name was emerald turquoise...
07-02-2014, 10:06 AM | #6 |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
07-02-2014, 11:15 AM | #7 |
"Junkyard Dog"
I spoke yesterday with John at Brothers which bought this seat (the one in the pics) from member GCncsuHD. He bought it with hopes to find a source to reproduce it. He says that the color and material is available but no luck on the ability to reproduce the pattern. He says that the color is Aqua. They offer a cover for the 67-68 seat in Aqua but it is a little off in color. That might be the way I go...
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
07-02-2014, 12:09 PM | #8 |
I started with the same seat. Ended up taking to my apolstery guy and got a close match. It might be a touch brighter, but nice. I wanted the factory pattern as well, but like others no luck.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
07-02-2014, 01:16 PM | #9 |
Subd..
07-02-2014, 03:39 PM | #10 |
BOHICA
Same issue here. My 68 has the same color interior with the light green exterior. Nobody seems to have a replacement that is the original color or pattern. I think I am going to have Truckseats do a custom one for me.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
07-03-2014, 10:00 PM | #11 |
That aqua was a common '60s automotive fabric color across the board in the '60s ('50s,too). I'd imagine SMS could come up with an alternative pattern from some other model. When it comes to reproduction trim,for the most part it's the upper level stuff that gets reproduced and the standard stuff is overlooked.
06-19-2019, 09:46 PM | #12 |
For anyone looking for light green/aqua seat alternatives, I had my local upholstery shop sew up a seat cover in Naugahyde Phoenix Dusty Jade (PH46), which I think matches the original seat color the best. The original seat didn't have any cording, so we kept it plain. While we couldn't simulate the fine heat-rolled pattern, the vertical stitches and center panel captures the basic farm truck look. Samples can be requested from Naugahyde direct.
https://www.naugahyde.com/catalog/pa...cfm?iteID=4134 I also chose to go with 3-point seat belts and center lap belt in Turquoise from Seatbeltplanet.com, which is the closest I could get to the seat color and the turquoise steering wheel. The carpet will likely be ACC 80-20 loop in Turquoise/Aqua (#508) from Stock Interiors. I'll order carpet after welding in the RH cab corner, outer rocker, kickpanel and front pillar/fender mount, hopefully in a few weeks. Looking forward to getting it assembled this summer. ~Tim |
06-19-2019, 09:57 PM | #13 | |
And Pictures. .
06-20-2019, 11:29 PM | #14 |
SMS Auto Fabrics says they can get the exact materials for my Custom seat, but those materials would be a little different than the base seat you have. They matched the color very well.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
06-21-2019, 08:23 AM | #15 |
That's going to be a sharp looking seat. Did SMS give any stock or part numbers with those samples? It's too late for me, but that B sample would probably be a good match. My Naugahyde vinyl color is close, but it's not metallic like the original material is.
06-21-2019, 10:16 AM | #16 |
They don’t give any part/stock numbers, they only give me this sheet and refer to the samples as A, B, and C. If I call them to order something, they have to look up my quote sheet to find what product I’m referring to. I think they do this so they don’t have to reveal the supplier and stock number.
06-21-2019, 10:22 AM | #17 |
Tim, I’m glad you posted the pics with the turquoise seatbelts. I have never trusted the seatbelt companies’ online color samples because the color accuracy depends on so many things, and my idea of turquoise is much blue-er than my light green pickup. But your post makes me think it could work. Think I’ll see if I can get a sample of the webbing.
06-21-2019, 10:40 AM | #18 | |
On your seat belts did they come with the clasps painted and do they have retractors? I got ones for mine with what looks to be the same webbing, but different clasps several years ago. At the time it was all I could find in the turquoise color.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-29-2019, 05:48 PM | #19 |
Sorry for the late reply. Yes, these seat belts have retractors. I'll try to remember to look at the seat belts tomorrow and possibly take a pic or two of the whole assembly. I believe the shoulder anchor bolt cover and retractor cover are black plastic, so they could be painted. Mine have the retractor brackets set up for no fuel tank.
06-29-2019, 09:06 PM | #20 |
I got new seat belt material from Seat Belts Plus. They make different weave patterns for different years. Worth checking into for your color you are wanting.
New buckles and tags from In Line Tube. The seat material is NOS from N.O.S. Automotive Fabric in Columbus, Michigan. It is the original material and exact pattern for my 1968. Tony and I talked on the phone and sent emails back and forth. He sent me pictures of the materials and advised me of measurements that I would need. I highly recommend them if your going back to original. |
