Old 06-20-2019, 05:16 AM   #1
72velle
72velle's Avatar
Tach on steering column
I have an 84 C10 and want to put a tach on the steering column. I am not looking for a huge racing tach with a shift light, just a smaller one to monitor rpms.
What are you using and where did you get it?
Thanks!
72velle is offline   Reply With Quote
Old 06-20-2019, 09:50 AM   #2
LeesTruk
Re: Tach on steering column
Got my tach from Speedhut, simple 6k tach mounted in an early Sun Tach cup (tach is designed as an in-dash unit)
LeesTruk is offline   Reply With Quote
Old 06-20-2019, 10:24 AM   #3
100%Chevy
I have a cheap one from O'Reilley's.About $39.00.
It's 2/2.5" I think. Pretty small but easy to read.
Mike.
100%Chevy is offline   Reply With Quote
Old 06-20-2019, 10:40 AM   #4
sweetk30
sweetk30's Avatar
i have been using these for years with zero problems . there 2 3/4" and can bolt down or feed a hose clamp threw and around the steering column . i find them for good deals on ebay a lot of the time.
6k rpm = https://www.autometer.com/2-3-4-tach...ini-black.html
8k rpm = https://www.autometer.com/2-3-4-tach...ini-black.html
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-20-2019, 04:46 PM   #5
Here is the one I used in my 81. I had a SuperTach, but it quit on me. That was the second time one failed on me so I found a cheapie on ebay and it works great. for $15 I could not complain. Seems accurat and been running great for a year now.
https://www.ebay.com/itm/UNIVERSAL-3...item1ed4ab3a3a
Palf70Step is online now   Reply With Quote
Old 06-20-2019, 05:33 PM   #6
cadillac_al
The Super Tach II from Summit is about as cheap as they get and works fine.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-20-2019, 05:42 PM   #7
truckin 79
I put mine under steering wheel, a small one
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 06-20-2019, 07:25 PM   #8
72velle
72velle's Avatar
Thanks! Great options! Thanks for the pics.
Old 06-24-2019, 04:14 PM   #9
demian5
demian5's Avatar
This has been my go to but I put it under the right side of the column, there is a screw where the dash makes a turn. Keeps it out of the way of feet as well. Like this in both of my square bodies (my 70 has a factory tach in the dash).
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
