#651 |
![]() Join Date: Dec 2006
Re: What did you do to your truck today.The 3rd chapter
Replaced doughnut gasket and tightened up header pipe, rehung left exhaust pipe and replaced the 2 3-Lbs coffee cans and baling wire that hold the round muffler together. Neighbors will never even hear me leaving at 06:00 anymore.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#652 |
Did a test fit of the wood for my 68. Now just need to cut to length and stain . I'm going with the lighter of the two blacks. New bedstrips should be in this week.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#653 |
This post isn't so much about what I did today.. More like what I've been doing the past year to fix a reoccurring problem.. When I bought my '71 in December of 2017, the fuel gauge didn't work.. When I removed the sending unit, I found the brass float had partially "dissolved".. I ordered a replacement along with a spare float a little less than a year ago. I replaced the unit, and before the truck had consumed a tank of gas, the gauge failed again.. The new float had developed a leak in the soldered seam.. I replaced the float with the spare I had ordered.. In a brief period, the second float failed at the seam also.. I contacted the company I bought the sending unit from and they sent me a replacement sending unit.. That was about a month ago, while the unit was still within the one year warranty.. Well ---- you guessed it.. Another float has failed.. I don't know what's causing so many floats to fail in the same area, but this time I'm looking at a different fix for the problem..
#654 |
Who Changed This?
![]() Join Date: Jan 2013
Crappy solder joint would be my take. When you solder the float pieces together, there will be low pressure inside as the parts cool. That can suck solder in, causing a leak. Maybe try a bead of JB Weld? I had a plastic one from a Buick that I sold. I ended up using that after one repair attempt on the brass float. I didn't think of the JB Weld at that time.
#655 |
Changed the engine oil.
#656 | |
![]() Join Date: Oct 2013
#657 | |
![]() Join Date: Mar 2005
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#658 |
Rained today so I went and bought more paint for the 68. My wallet is very light now
![]() Grumpy I'll post some pics of the unpatina'd truck in the next few weeks
#659 | |
Who Changed This?
#660 |
I guess all you guys that replied to my post about the multiple fuel gauge float failures think I'm some kind of pompous snob because I never posted a response.. In keeping with Liz's intentions for starting this thread, I remained in the background, as it wasn't my intentions to seek help with a solution to the problem.. I already knew what I had to do.. I want to thank each and every one of you for the solution contributions..
Now as to what I did to my truck today.... I ordered later a model fuel gauge sending unit, one with the third line intended for fuel recirculation, and a plastic float to go with it.. I broke out my trusty tubing bender and a few clothes hangers.. While I wait for the new parts to arrive, I've installed a mechanical fuel pump to replace the noisy electric unit. Also, I'll be bending up a return line.. Looks like I have enough to do for the next few days... Now back to our regularly scheduled programming.. |
#661 |
Blasted one side today. The blaster will only do fine slag or crushed glass. Little slow on rust but takes the paint off nicely. Not a lot of heat either. Kept checking it with an infrared thermo.
But it is nice not doing any rot work. I may just paint the inside of the fenders body color. Black specks is what's left of the undercoating not rust
#662 |
![]() Join Date: Oct 2014
Going to the GoodGuys Nats in Columbus, Ohio in a couple of weeks so I put my "High Tech" tool box in the bed to keep stuff dry in case of rain. I needed a way to hold it in and not wanting to over engineer it or drill holes in the pristine bed floor I came up with a couple of 1/8" by 1 1/2" straps bent 90 degrees and was able to remove two bed mounting bolts and use the holes to fasten the box down. When I decide to remove the box I can replace the original rusty headed carriage bolts.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
#663 |
I found my exhaust leak!
Header installation in process... Anyone interested in a slightly used , original rams horn? Lol! |
#664 |
At the body shop.
Cleaned up a mess under the seat.
And ditched the stack of spacers under the seat And put in new 3 point belts from T korinek The belts went in and work perfect.
" That didnt make it any newer " " Dont antique the equipment " |
#665 |
Wanted to change out my steering box, but can't find it local ( I'm not paying $800). Instead I ran new rubber fuel lines and changed all the in line filters. My timing light arrives tomorrow so will check timing and maybe see if I can adjust my carb.
Back story-purchased truck from neighbor. They had it since 2015. Had plans to restore but didn't get very far. So it's mine now, so minimum 4 years of sitting. I want to restore and start cruising it. Slowly finding parts needing replaced. My back ordered heater core finally arrived after 3 months on order. Trying to get it road worthy for now. |
#666 |
Got one of my saddle tanks back on-line.
"Fixed" my ancient exhaust system replacing the manifold to pipe brass nuts and changing out the coffee cans that hold the muffler together. Replaced windshield washer hose but there is not enough pressure to squirt more than a few inches, still not bad for not having worked for 30 years. Fixed charging system (wire to Ign. Switch came loose). -BA
#667 |
Cab and bed finally off! No turning back now, is there?
#668 |
Active Member
![]() Join Date: Nov 2015
Fixing some minor safety issues. Coil spring was broken off in the control arm. Ball joint fell out of arm. Hopefully the airbags, newer control arms(68’) and new ball joints get rid of the rattling death feel. Real curious how long it’s been broken since I’ve been driving 50 miles a day last few months.
Posted via Mobile Device |
#669 | |
Do it, Do it right, Do it right the first time |
#670 |
Works great. Was way out in bumfuc and saw that my tank was being supported by the exhaust pipe after the support dropped through the bed wood. So I did what I could. Right now I'm too busy to worry about fixing it the right way (new bed wood). I thought you guys would get a laugh.
Oh, that other "structural support" is a section of 4" plastic bender-board that i sawed a notch in with a carpenters saw.
#671 |
Active Member
I finally stretched the tonneau cover on, I stitched up on camper. Now the bike can survive the sun. One step closer.
#672 |
Who Changed This?
Cool!
Yesterday and today my son drove the truck to do some handy man work. He loves that truck! When my wife and I shuffle off this mortal coil, he's going to be the recipient. All my tools, too. The other two have no interest in any of that. ![]()
#673 |
Painted the inner fender area on the step side. Now I'm sanding the steps and fenders hope to get it painted today.
#674 |
Active Member
![]() Join Date: May 2016
I removed the heart...
#675 |
![]() Join Date: Sep 2018
Sand, sweat, get covered in dust, repeat...
1972 Cheyenne Super SWB 2wd 402 Orange & White 1971 Cheyenne 3/4 4wd Black & White 1972 Cheyenne Super 1/2 LWB 2wd 402 Red & White 1968 Chevelle SS 396 L78 |
