12-18-2018, 04:07 PM | #51 |
Re: Please post pictures of your C10 w/US Mags Rambler rims
New stance, same wheels!
12-18-2018, 09:37 PM | #52 |
Here are mine. 22x11 &22x9
12-19-2018, 09:28 PM | #53 |
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
12-20-2018, 06:04 PM | #54 |
Anyone running these with an 8.5" wheel on the front? Backs easy to get back space but fronts a little different
12-20-2018, 07:09 PM | #55 |
Here you go
12-24-2018, 05:56 PM | #56 |
20’s & 22’s
12-26-2018, 09:51 AM | #57 |
I know I love the look of these wheels, but damn these trucks look great
12-26-2018, 11:38 AM | #58 |
Did you bag this truck and what BS are the wheels? It looks awesome
12-26-2018, 03:14 PM | #59 |
Heres my 72' K5 with 20/22 ramblers. The truck has a simple bag job with a bolt in notch.
Fronts are 20x8 with 4-1/2" BS Rears are 22x9 with 5" BS
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
12-26-2018, 03:16 PM | #60 |
Very Nice! Happy New Year
04-19-2019, 10:15 AM | #61 |
Hi everyone. I posted a thread about the CPP spindles (non modular) and track width, but got no answers. So I figured I'd rephrase my question and ask it here. I have a 71 C10 and plan on running the 20" rambler wheel with a 4.5/6 drop. From what I've read ideal BS for a 20x8.5 wheel with that drop is 5.25-5.5. The rambler wheel only comes in 20x8 with a 4.5 BS. I am going to be ordering PBFab control arms and am trying to figure out if it would be better to get the 1" narrow ones. Anybody using those spindles (CP4S4-3) and that drop with the 20" rambler wheel ? Or with any input on the matter ?
much thanks |
06-25-2019, 03:22 PM | #62 |
Nobody has any input ? Anyone run the 20x10.5 on the rear ? What modifications if any ?
06-25-2019, 04:11 PM | #63 |
So I have the 20x10/w 5.5" bs. I also have a 69 so the rear end is narrower. I had to use .5"spacers, 3/4 would be perfect but dont like that idea. The same wheel on your truck would be perfect bit not sure about the 10.5". You might have to massage the outer wheel well a little. I got nothing for you on the front with the control arm. Mine has stock arm and running a 8.5"wheel with no problems. I would think your arms might have a better fit, but not sure.
06-25-2019, 05:29 PM | #64 |
I have the 22x11 in the rear and had to run 3/4” spacers and only have about 1/2” clearance between the inner fenders. I have the 71-72 axle. I was leary about running spacers that big but I had a set of hub centric spacers made so it isn’t putting all the stress on long studs. I’ve put 4 or 5k miles on them with no issues.
06-25-2019, 08:08 PM | #65 |
Thanks for the input guys. So neither of you had to widen the tubs ? Don't really want to but would if that's what it takes.
06-25-2019, 08:30 PM | #66 |
My tubs are factory. As far as the front end, I have the 20x8 4.5” BS. On 3/5 drop and I’ve got no fitment issues.
06-26-2019, 12:05 AM | #67 |
Here's mine. 20x8 and 20x9.5.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-26-2019, 10:21 AM | #68 |
06-26-2019, 01:38 PM | #69 |
Truck goals, right there! Damn! That is what mine looks like in my head... now I have an actual idea of what it really looks like.
Very nice truck!
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
06-26-2019, 04:53 PM | #70 |
255/40/20, it’s hard to tell man. You will just have to do some measuring especially since you plan on running aftermarket control arms. The clearance I’ve got is on factory length arms. I’ll attach a close up pic of the front end just to give you an idea anyway.
06-26-2019, 04:55 PM | #71 |
06-26-2019, 07:45 PM | #72 | |
01-20-2020, 06:09 PM | #73 |
Curious for those that have these wheels.... How do the front 'center cap' area of the wheel attach? Are they actually part of the wheel or an actual cap?
01-21-2020, 09:58 AM | #74 |
It's a push-in cap.
01-21-2020, 11:03 AM | #75 |
Clipped in place or O-ring? Is the cap just chromed plastic?
