06-26-2019, 05:13 PM | #1 |
Vacuum Line Frustration
So, I have done lots of hunting on Google, and scoured the Service Manual and I'm about ready to pull out my hair trying to untangle the mess a former owner left for me. I don't see any examples of a 4 port charcoal canister on a truck without EGR, and other than in the service manual, I dont see any examples of a second PCV ran to an air cleaner riser like mine. But the PCV lines are the only ones the manual references.
My truck is a 1971 C/20, 350, Quadrajet, no AC, no cruise, should be simple, right? I'm mostly sure the PCV lines, as well as the two lines that are currently connected to the charcoal canister (to PCV and Tank) are correct. I think the distributor is also correct (D1 to V1). I'm also guessing the small canister port goes to the timed vacuum port (C2 to V3). Where should the large canister port closest to the fender (C1), and air cleaner port be routed to? Also, what gets connected to V2, and is it to the fuel bowl? I will attach a quick diagram, as well as a few images of what I am dealing with. |
06-26-2019, 07:15 PM | #2 |
Proprietor of Dale's Corner
Re: Vacuum Line Frustration
My k20 doesn't have a charcoal canister. I didn't think any of the 3/4 tons did.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-26-2019, 07:17 PM | #3 |
The line from the riser to the valve cover is just an air supply breather. You need air supplied to your motor to mix with the fumes and moisture that are pulled out of the motor with the pcv.
Your other mess of hoses basically hooks up your manifold vacuum port (v2) to the ported vacuum port (v3). Your distributor vac pot shouldn’t hook to v1. That’s a manifold vac port that should hook to the small barb on the canister. Not sure on the rest of the stuff on the canister. Does your air cleaner snout have a opening for a choke stove pipe? |
06-26-2019, 07:21 PM | #4 |
Mine was built in Fremont, I'm sure I can blame California. I don't see any evidence of EGR being equipped so at least I'm lucky there.
06-26-2019, 07:52 PM | #5 | |
My air cleaner does indeed have a stove pipe and a vacuum diaphragm, choke is divorced on the intake. Why would I want to connect manifold vacuum (V2) to ported vacuum (V3)? |
06-26-2019, 07:57 PM | #6 |
Who Changed This?
I don't recall seeing vapor recovery canisters on 3/4T and larger trucks in '71, and for certain they didn't have EGR. So there has been some swapping around going on. Has the cab on your truck been transplanted from a different vehicle? If so, and it was more recent manufacture than '71, it could have the vapor separator lines in the cab. It'll be obvious from looking at the tank, as there will be multiple lines to it, not just the fuel pump suction line. What does the SPID say about California emissions equipment?
06-26-2019, 08:01 PM | #7 |
Air cleaner might have the stove pipe fitting but do you have the pipe and stove on the manifold?
Youdon’t Want manifold to ported. Seems po did though. I’ve seen v1 hooked to the canister normally. As to where to hook your vac advance is debatable. You could have a 10 page thread with everybody’s opinion. What’s your ultimate goal? Concourse restoration or just what’s needed Hooked up? |
06-26-2019, 08:36 PM | #8 | |
06-26-2019, 09:06 PM | #9 | |
06-26-2019, 09:53 PM | #10 |
Aircleaner vac line hooks to manifold vac thru the temp switch in the aircleaner.
06-26-2019, 10:26 PM | #11 |
Carpe manana
Is that a CA emissions carb? Code on the LH side could let us know. Looks like has the extra port out front but don't have access to mine to compare at the moment. If so, just cap that one. The side port can go to the air cleaner. Those tee fittings are for use with the CA system and/or AC vac hoses I suspect. The larger diameter hose at the base would use a tee fitting and I think one end would send hose to the charcoal can.
06-26-2019, 10:33 PM | #12 | |
Who Changed This?
06-27-2019, 12:26 AM | #13 | |
The carb is part no. 7041208 DN ?380. So using a magic decoder ring, 70-75 model, for a 71, Fed. standard 4bbl, for a Chevy, automatic?, built the ?38th day of 70. From my reading, the manual vs. auto marking can be dependent, and Fremont was notorious for doing things wrong, hence why it builds Teslas now. |
06-27-2019, 01:06 AM | #14 |
Been awhile since I've done smog checks, but let me give it a run
V1 to A1---maybe another sensor under the air cleaner C1 stays open unless it is labeled V3 to D1 teed to C2 Plug V2 PCV Teed to caniister |
06-27-2019, 01:21 AM | #15 |
Take it all off and throw it in the trash , You'll feel like your on vacation .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-27-2019, 02:11 AM | #16 |
Thanks for all the sagely advice gentleman! Between geezer and kwmech I think I should be able to stop removing hair the hard way. Ill try it both ways and see which works best, and maybe I will draw up a less cheesy diagram for the next guy who may need it.
I will say, Grumpy has the simplest answer. But I like to put things back to stock before I start modding, easier to tell if I'm the bumbling idiot that way. |
06-27-2019, 03:05 AM | #17 |
If there are no smog checks required for this year in CO then I would delete all of this also. Evap is nice in the summer though to help keep the odor out of the cab.
06-27-2019, 05:55 AM | #18 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-27-2019, 07:06 AM | #19 |
Block the extra vacuum ports on the carb and just run PCV and vacuum advance.
If that canister is damaged, you will end up adding a vacuum leak.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-28-2019, 02:04 AM | #20 |
Fixing that old canister is going to be a 2-400 dollar pita. Its all the little crap you have to buy.
Drop kick that EPA thing back to 1967, it wont work there either. |
06-29-2019, 03:02 PM | #21 |
06-29-2019, 03:22 PM | #22 |
You guys have talked me into just that. About to go buy some fuel line and vacuum line, as well as some other tune up stuff as we speak. I'm thinking I may use the vapor hard line back to the tank as a fuel return line with an AMC style vapor return fuel filter to help fight vapor-lock, but the canister is already out of the mix.
