![]() Join Date: Feb 2003
250cu. in. with powerglide... which flex plate?
i am replacing my worn out 292... 3-on tree. with a brand new 250cu.in. crate engine and a fresh powerglide from a 65-66 c10. my question is which flex plate? and converter do i use?
any help ? thx dave
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
![]() Join Date: Aug 2004
Re: 250cu. in. with powerglide... which flex plate?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
i thank you for your responce, my question is ? is the 230 flexplate the same as 250 flexplate?
![]() Join Date: Oct 2005
The 230 & 250 use the same flexplate. Use a converter for the power glide & a flex plate to match. The small block v-8s used the same flex plate were it bolts to the engine but I'm not sure if the bolt pattern to the converter will fit.
George |
Same block 230/350
I think he's looking for a flex plate, not a flywheel.
#7 | |
i thank you, dave yes ... flex plate... thx dave
60-66 Nut
There are 2 diameters of flexplates for the I6 and V8's. The 153 tooth 12-3/4" and the 168 tooth 14". You will need the correct starter for the diameter of flexplate that you choose.
Some starters will do both flex plates.
#10 | |
thank you.
