07-04-2019, 02:19 PM | #151 |
Re: GMC and Chevrolet VIN and Model Number Decoders with pics.
Just for fun check to see if you find any Blazers with a build sequence starting with a 8. Line 2 builds started with 6 and line 1 builds started with 8. (1971 Flint) I'm curious to see if all the Flint blazers were built on line 2 or both lines. I don't have any blazer SPIDs 1971 Flint that the sequence number starts with 8, but you might.
CHEVY/GMC VIN DECODERS |
07-04-2019, 03:17 PM | #152 |
Carpe manana
I'm relying on those examples documented on the Blazer SPID thread. All of the 71 MY Flint built examples begin with 6 - there are no 8s to date.
I'll check the thread for Jimmy SPIDs and will post back if there are any Flint examples from 71.
07-11-2019, 01:32 PM | #153 | |
Line 1 was specific to pickups. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-11-2019, 02:48 PM | #154 |
Thanks Keith, Always good to hear it from the source.
01-17-2020, 02:06 PM | #155 |
Recently picked up a 1969 GMC K2500 and i was wondering what the X in the VIN stands for? On the VIN decoder it says that space should be a dash or a special designation. Thanks for the help!
'72 K20 Ochre/white 350/350/205 4" Lift 35's '72 GMC K10 red orange/white 400/350/205 '69 C20 Longhorn 454 TH400 '72 Blazer CST 4x4 '70 Blazer 4X4 |
01-17-2020, 03:04 PM | #156 |
Jay, Does the VIN on the door jam(metal plate) have the X?
01-17-2020, 03:26 PM | #157 |
That's a great question! I will look this afternoon when i get home.
01-20-2020, 01:54 PM | #158 |
The VIN tag on the cab has the dash. The X must have been a default letter for the dash in the printing system.
01-20-2020, 02:48 PM | #159 |
I could use help reading the vin on my 1970 GMC Jimmy. The vin does not seem to match up correctly to the 1970-1971 GMC vin decoder. Any help.is appreciated.
01-20-2020, 07:15 PM | #160 | |
Moderator
K 4 WD E V8 1 1/2 Ton 14 Jimmy S St Louis Z 1970 71,554 build identity These are available in the first few pages of the LMC catalogs if you download the PDF file of the catalog... Hope this helps...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
01-21-2020, 12:49 PM | #161 |
Jay, So your vin does not have a special destination code, as the VIN plate is the definitive answer. The X on your SPID is unusual and most likely a assembly line mistake. The VINs on the SPID, were printed at a different time from the printing on the rest of the SPID. So who ever printed the VIN on your SPID put a X where a space should have been. I don't know why or how but it's a mistake. Other 1969 GMC SPIDS from St. Louis got it right.(space, no X) Kind of a cool anominaly that makes no difference at all. And it took 50 years for someone to catch the mistake.
03-01-2020, 09:37 PM | #162 |
Hi. I bought a short bed chassis for my project. I want to see if it’s possible to decode it? Like what year it is etc. The number stamped on the chassis on the driver side is 2z130693. Any help is greatly appreciated.
Posted via Mobile Device |
03-01-2020, 09:56 PM | #163 |
72 Fremont built truck - the last 6 digits would match the last 6 digits of the VIN of the cab plate that was previously on the chassis. If original, it should have front disk brakes.
03-01-2020, 11:04 PM | #164 | |
02-06-2021, 03:18 PM | #165 | |
02-06-2021, 10:41 PM | #166 |
Ryanz, Yes, because it rolled over after 10,000 trucks were built(for the USA market). Your truck was 10,539 to be assigned a vin number in 1971 at Oshawa for the American market. GMC's built at Oshawa for the Canadian market used the Chevrolet VIN format and used a 9 between the Chassis and Engine codes to denote GMC. They also used 100,001 as a starting number.
But because your truck was going to the USA, it uses the USA GMC format which has a starting number of 10,001. That's 10,001 with the first truck. So 20,539 - 10,000 is 10,539. Thanks for the kind words, Bruce
02-06-2021, 10:55 PM | #167 | |
02-06-2021, 11:04 PM | #168 |
Yes GMC's in general. As far as the serial number is concerned they don't care what type of truck, just if it's a light duty truck or not. 1/2 ton or 3/4 ton, fender side or wide side, v8 or six cylinder. They don't care when issuing the serial number. If it's a light duty truck it gets the next number in the sequence.
02-06-2021, 11:07 PM | #169 | |
02-06-2021, 11:13 PM | #170 |
Yes, Info on the trucks built in Canada can be purchased still. But I doubt it will tell you production numbers. Mostly just how the truck was optioned.
Do you have the sticker on the inside of the glove box door? It will have the options on it.
02-06-2021, 11:16 PM | #171 | |
02-10-2021, 06:50 PM | #172 |
Thank you so much for this thread!!
All of you folks that post questions as well as answers ROCK!! I love my treuck and I love all the fans of trucks! Thanks again! |
03-05-2021, 07:15 PM | #173 |
New Member
Chevrolet and GMC medium and heavy duty trucks, I picked up a 1970 Chevrolet C50 and looking at what I think is a 1973 gmc 5500. Can you decipher the vin#?
CE503-Z124050 |
03-06-2021, 09:29 AM | #174 |
I’m kinda curious about the medium duty trucks as well.
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10” |
03-06-2021, 10:54 AM | #175 | |
Who Changed This?
Here you go-
