06-29-2019, 08:46 AM | #3076 |
Re: PO has me PO'd
ahh DUNCAN YoYo been there done that wish I had saved one I too shall be a spring chicken August 17th turning 68 years young...Happy Birthday Jim
Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
07-01-2019, 07:22 AM | #3077 | |
Re: PO has me PO'd
Us spring chickens have got to get together
07-04-2019, 06:43 AM | #3078 |
Re: PO has me PO'd
tank is mounted in truck, filler neck hose installed. What a pita putting tank up even with a trans jack
seems the repop manufactorer coundn't measure, as the mounting holes for the "U" bracket were off by a 1/4", didn't have a tool to do the job quickly so I just grabbed a rat tail file, and made a bunch of noise Later will install rubber, between tank and straps. also, received a filler neck clamp from Eric(1972 jimmy). Didn't even know they had a clamp
07-05-2019, 08:01 AM | #3079 |
Re: PO has me PO'd
07-05-2019, 08:07 AM | #3080 |
Re: PO has me PO'd
finally was able to use my wobbler/center finder I bought several months ago
[url=https://flic.kr/p/2gpEbJe]20190702_135842
07-05-2019, 11:48 AM | #3081 |
Re: PO has me PO'd
07-06-2019, 10:52 AM | #3082 |
Re: PO has me PO'd
oil pan is up,but not without a struggle. My all thread didn't work as planned, the back corners hit the all thread, but the front was ok. I've bought 2 of these gaskets and neither on came with those 4 gizmos that help with installation
I have to open up the holes in the clamps for 1/4-20 studs. I have a press / punch with dies, want to see if it works on SS, I have to find the pliers that close these clamps [url=https://flic.kr/p/2gspivY]20190706_101712 [url=https://flic.kr/p/2gsp2LF]20190706_101726 [url=https://flic.kr/p/2gsp48J]20190706_101800
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-06-2019 at 10:59 AM. |
07-06-2019, 11:38 AM | #3083 |
Re: PO has me PO'd
I always glue the gaskets, even the one piece, to the pan with black RTV and let it sit for a few hours or overnight. I put the pan bolts down through the holes to keep them aligned, and also use some blue tape. Gasket stays on the pan whether it is upside down when installing on an engine stand or when putting it on the engine when it is in the truck.
It's looking good Jim.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
07-06-2019, 02:18 PM | #3084 |
Re: PO has me PO'd
The one piece gaskets don't need any glue or RTV. Just make sure the block and all mating surfaces are clean and bone dry.
Here's the Snap-ups you're talking about. Don't know how I put up a pan and gaskets before without them. Huge difference. https://www.summitracing.com/parts/fel-es72863 |
07-06-2019, 07:00 PM | #3085 | |
Re: PO has me PO'd
07-06-2019, 08:28 PM | #3086 |
Re: PO has me PO'd
By the way Jim, what is the capacity of that pan?
07-07-2019, 07:42 AM | #3087 |
Re: PO has me PO'd
thanks for your ideas guys, but I sorta went with both, just RTV'D the 4 corners where it made a sharp bend. ran my primer device yesterday and no leaks so far. But, who knows what will happen when the engine gets up to temp. and full pressure.
the pan is a 8 quart, just a heads up, they didn't deburr inside where it was cut and welded so be careful when you wipe it down [url=https://flic.kr/p/2grFkpA]20190705_095016 thanks for the link on the parts AJ. I just may buy them and keep in tool box
07-08-2019, 10:34 PM | #3088 |
Re: PO has me PO'd
we shall ...I may have more time on my hands soon ....and take a ride when it works for us ....share a birthday cheer...
07-11-2019, 08:13 AM | #3089 |
Re: PO has me PO'd
Well, since you're my little brother, i'll take you out for dinner, Mexican or ?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-11-2019 at 12:08 PM. |
08-29-2019, 01:45 PM | #3090 |
Re: PO has me PO'd
my shop is empty, moved over to injection connection, sure feels like a load has been lifted from my shoulders. I'll let Dale handle my problems for now....
first problem he saw was the sealing of the pump to tank, he offered suggestions. I'll post up when I get more info. Yes, that is one of the shelving units loaded with Jimmy parts, I'll sell them off as I don't use them [url=https://flic.kr/p/2gEFFfj]20190722_194138[ one eye instead of four [url=https://flic.kr/p/2h7pLiM]20190829_100502 [url=https://flic.kr/p/2h7pLo6]20190829_100619[
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-29-2019 at 01:58 PM. |
08-29-2019, 01:52 PM | #3091 |
Equal opportunity joke ofender
Re: PO has me PO'd
Glad to see you making some progress on this Jim. Looks real nice out in the open shop like that.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
08-29-2019, 02:06 PM | #3092 | |
Re: PO has me PO'd
Computers are installed using my mount, wiring is installed at main harness and working on fuel tank seal Dale is a wiz at this early TPI set up, He was just out at the salt flats tuning cars
08-29-2019, 06:03 PM | #3093 |
Re: PO has me PO'd
I see a grand national in your picture, does he work on them also?
08-29-2019, 08:26 PM | #3094 | |
Re: PO has me PO'd
08-29-2019, 10:39 PM | #3095 |
Re: PO has me PO'd
great news moving the project along Jim, shop looks lonely ...
08-30-2019, 06:46 AM | #3096 | |
Re: PO has me PO'd
4-8 weeks is what he quoted me, but at this time it doesn't matter as she is getting worked on. Thanks for following Thanks Jesse, just bought an old boston whaler, so I have another project waiting to go in the shop, wish I had a bigger shop sweet '55 you have been working on, glad the gas tank swap went well
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-30-2019 at 06:51 AM. |
08-30-2019, 09:20 AM | #3097 |
Carpe manana
Re: PO has me PO'd
Great progress Jim - ready to drive before the snow flies maybe?
09-01-2019, 08:48 AM | #3098 | |
Re: PO has me PO'd
Your trucks look fantastic, glad they made the move well, hope you enjoy the cold and snowy cold north
09-01-2019, 10:41 AM | #3099 |
Carpe manana
Re: PO has me PO'd
When I lived in MT I’d drive my k20 in salt free snow and had a good time. Too much salt here to consider it. I’m told that some car washes here recycle the undercarriage wash and it can be like brine - I’ve identified a car wash that doesn’t recycle water.
Thanks for the good words. Having a great time here!
09-01-2019, 05:59 PM | #3100 | |
Re: PO has me PO'd
Thanks for entertaining me with you're great builds and info. of said builds. I always key into a thread when i see you post up
