Old 05-29-2004, 11:47 PM   #1
Rakort
Parting out a 69 3/4 GMC Long and Wide
Bought a donor truck. It will donate to my 68 C10 the 350 Engine, rad, steering column, TH350, cross member, drive shaft, sway bar, and a few other things I'm sure.
Basically the rest of it is up for grabs. Body is pretty though including the bed...no tailgate. It is located in Neenah WI. Let me know if there is anything I can help with.
Rakort is offline   Reply With Quote
Old 05-30-2004, 02:10 AM   #2
longhorn70gmc
longhorn70gmc's Avatar
Donor Truck
Hello Rakort,
By chance does it have any 3/4 ton GMC hubcaps with the black star in the middle? Looking for Stainless or regular steel painted ones. Thanks,
Longhorn70gmc
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 05-30-2004, 08:53 AM   #3
craigg1
What kind of condition are the doors in?
craigg1 is offline   Reply With Quote
Old 05-30-2004, 09:56 AM   #4
Rakort
Sorry guys, no hub caps and the doors are pretty much junk. BTW this is a Camper Special Truck what ever that means. The Hood is the only panel worth re-using.
Old 05-30-2004, 04:02 PM   #5
No3Fan4Ever
Running on empty
No3Fan4Ever's Avatar
Rakort,
Any mirrors left? I am looking for the medium size camper mirrors; they would be smaller than these ugly things.........
We have two rules here at the Rock.
Rule #1: No writing on the walls.
Rule#2: Obey all rules
70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi;
94 Bronco XLT 302, auto;worn out daily driver
No3Fan4Ever is offline   Reply With Quote
Old 05-30-2004, 04:21 PM   #6
longhorn70gmc
Hubcaps!
Rakort,
Bummer on the caps, but thanks anyway.
Longhorn70gmc
Billy
Hub Cap Freak!
Old 05-31-2004, 11:50 AM   #7
Rakort
No Mirrors
No Hub Caps
Doors might be better than I thought....I'll look again
Keep trying guys we will find something!!
Rakort
Old 05-31-2004, 12:42 PM   #8
1-PU70
1-PU70's Avatar
Im looking for the wire that conects to the water temp sending unit. The end that clips to the sender and some wire.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 06-02-2004, 02:45 AM   #9
Jerrys1stgJimmy
hows the front clip?
Jerrys1stgJimmy is offline   Reply With Quote
Old 06-02-2004, 07:39 AM   #10
Rakort
Bumper is decent except a twist, hood is good, fenders are ? and at least one has been changed already. The grill is straight, but has some surface rust on the bottom. I'd rate it fair overall.
Old 06-02-2004, 09:13 AM   #11
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
if it was a camper truck it probably has desirable rear gears......you should check that..
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 06-02-2004, 10:18 PM   #12
Rakort
I believe it was a camper special. What are the desirable gears / rearends? A particular ratio?
Rakort
Old 06-04-2004, 05:14 PM   #13
OhioDan
OhioDan's Avatar
Brown seat belts?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
