Old 07-07-2019, 08:01 PM   #1
GSP7
GSP7's Avatar
Square body end years, trucks vs blazers , crew cabs, suburbans 4x4
What years did the square bodies end for trucks vs blazers and 4x4 and suburbans
I also asked here
http://67-72chevytrucks.com/vboard/s...d.php?t=789860
I found a nice, original paint Blazer 89-91 Ive been eye balling. Looks all original 'cept 4" lift and nice 10" wide aluminum rims and 33" tires . Im hoping the owner might sell it to me at a good price
Little research ive done , its a TB Fuel injected, computer ignition, 89-91 blazer. Think its a center bolt valve cover engine too. One piece rear seal SM Block? Did these have a 700r or 460r over drive trans?
Looks like this, Metalic dark grey with white two tone, Smaller tires, 4" springs, than this pic
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 07-08-2019, 12:47 AM   #2
kipps
Re: Square body end years, trucks vs blazers , crew cabs, suburbans 4x4
Copying from wikipedia, which sounds correct, but I can't guarantee it...
final model year of production for the rounded-line(square body) trucks.
regular cab trucks in the US -- 1987
regular cab trucks in Mexico -- 1991
cab/chassis trucks -- 1989
crew cab trucks -- 1991
suburbans -- 1991
blazers -- 1991
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 07-08-2019, 04:19 PM   #3
Bigdav160
Bigdav160's Avatar
One piece rear main and technically the transmission is a 4L60 but that is just a renamed 700R4. It is not computer shifted
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-10-2019, 11:01 PM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
The vin will tell you the exact year. 89-91 used the same grill for the Silverado models like in the pic.
90-91's will have some unique items like an electric speedometer with 6 digit odometer. The 90-91's also have roof mounted 3 point seat belts for the rear seat passengers.
The auto trans 700r4 was renamed internally as the 4L60 (no "e") by 90. The "e" is what stands for the electronic control function which the 700r4/4L60 did not have.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 07-12-2019, 06:28 AM   #5
Wiki is correct, except you could get a regular cab dual rear pickup through '88
