Sway bar mounting flip
I’m sure I’m not the first to think of this. But I thought I’d share the idea.
After lowering my c20 the original sway bar didn’t align nicely with the mounts in the control arms. What I did was remount the sway bar on top of the original stand off brackets. I had to knock out one rivet at the front of one bracket then I passed the sway bar through the other side and bent the bracket down far enough to push the sway bar through. Then I bolted down the sway bar and put in a grade 8 bolt to replace the rivet I knocked out. This saved me buying the low profile brackets offered and seemed to me a lot less work. The bar aligns perfectly now. This is on a 69 C20 so I’m unsure if the C10 bracket is any different and this is a stock sway bar. But worth a look if you’ve lowered your truck. I’ve attached a few pics. The original mounting, the flipped mounting and of course the truck.
John 69 c20, 396, th400, dana60, ps, ac |
Re: Sway bar mounting flip
Arghhhhh up side down pics
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
That's exactly how I did mine! Works great on the lowered trucks!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Yeah figured it would have been done before. But that didn’t stop me feeling pretty clever.
Ingenious. Nice work.
![]() Join Date: Dec 2013
All the pictures you guys from down under post are upside down on our computers .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
That's a great idea, first time I've seen it.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Does not work on all OS's.
• Ctrl+Alt+↓ - Flip the screen upside down. • Ctrl+Alt+→ - Rotate the screen 90° to the right. • Ctrl+Alt+← - Rotate the screen 90° to the left. • Ctrl+Alt+↑ - Return the screen to the standard orientation. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
At the body shop.
Knock the bracket off. And bolt the bushing clamp to the rail.
Rare to see an un bent bracket.
" That didnt make it any newer " " Dont antique the equipment " |
#10 | |
Upside down and on the wrong side of the road.
#11 | |
I did consider knocking off the bracket, but took the easy way out. The whole trucks in great condition. I don’t think it was ever used for work. Rockers, cab corners are original and rust free. Tailgates straight, beds in great condition and the paint is mostly from 1969. If it was a shortbed c10 I’d be sitting on a goldmine.
John 69 c20, 396, th400, dana60, ps, ac Last edited by Aus69c20; 07-22-2019 at 08:22 PM. Reason: Mistakes |
![]() Join Date: Dec 1999
fixed for you
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Thanks Richard
![]() Join Date: Sep 2007
i did that to mine too.... more clearance
1967custom |
#15 |
did not know this!!! thanks !!
1967custom |
