#251 |
Re: lowered shortbeds on stock wheels?
3/5 drop
#252 |
85 thats 90% done final assembly.
5.3 / 4l60-e 12 bolt rear / 2.5" spindles front and 2" hanger rear and 1" longer shackle rear for total of 2.5 . still has stock rake but lower . rollers are 88-98 sport rims and 31" tires for now . going 255/70/15 on 15x8 ralley unless i find some cool old school aluminum's . front bumper swap to 4wd air dam no tow hook cut outs for a 1.5" lower look over the 2wd air dam .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#253 |
Lowered with 2.5" Western Chassis spindles in front (stock coils) and 4" in rear with dearched springs. 15x8 rallys in front with 235/70/15 and 15x8 rallys in back with 275/60/15......almost stock wheels lol!
1980 Silverado short bed 1993 GMC 1500 LS swap 2006 Lifted Z71 Crew Cab |
#254 |
![]() Join Date: Nov 2008
Just got mine back on the road ..
#255 |
#256 |
Here you go.
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
#258 |
Here’s my ‘77 lowered with 2” spindles + 2.5” springs and flipped in the rear with stock 3 pack leafs. It’s on 15x8 fronts with 245/60R15s and 15x10 rears with 275/60R15s
#260 |
Nailed it! Timeless right there.
#261 |
Junior Member
78 Sierra. Original owner's son said it never spent a night under cover.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
#262 |
my daily
![]() btw no bags Last edited by badfarmtruck; 09-16-2019 at 11:26 AM. |
#263 |
Good looking truck!
It will be asked: How was the drop done? What are your parts specs/tech info?
#264 |
front:
3" spindles 1 coil cut off stock springs 2" sectioned crossmember with 3 degrees of caster added no limit rack and pinion (do not use bad bump-steer) inner fenders raised rear: stock long leafs flip kit 4" shackles/hangers small c notch I drive this truck every day and ride quality is pretty good. |
#265 |
I like these truck rallys more than my corvette rallys.
