Roto Reuter thats the name...
![]() Join Date: Feb 2010
NP205 install question
I've searched this with no luck. Do I need to put some type of silicone or RTV on the adapter-to-NP205 bolts. Some of these bolt holes are open to oil side. Thanks.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Re: NP205 install question
first off there needs to be the correct gasket between the 205 case and adapter or you WILL break the adapter when bolts go tight .
and if me i would put a little rtv on the threads to seal them up were there a open hole in to the case just so its less of a leak point down the road .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Yes I have the proper gasket to go between the adapter and transfer case. Actually I'm doing an engine swap going from 307/SM465/NP205 to 5.3L LM7/4L60E/NP205. I'm using Advanced Adapters for the NP205 10-spline to 4L60E. They sent me the gasket. I have read that you must use the gasket, but I wasn't sure about sealing the bolts. If I couldn't find anything I planned to put some RTV on the bolts. I also read several posts about NOT using the NP205 torque mount that installs to the frame. I'm not sure about that one yet.
just making sure you know the gasket was all .
and most now say no frame to t-case mount it can brake the trans tail housing in frame flex off road stuff . better to do the newer trucks brace rod from t-case to bell housing bolt / stud .
![]() Join Date: Mar 2003
Pic one or 2 holes that go through into the oil cavity and install a stud. Makes it easier when installing and trying to line things up. Those things are 150 lbs.. ish
![]() Join Date: May 2012
I think it's the 465 side of the adapter that has a couple of through bolts at the center. And the PTO covers each have a couple through bolts too.
I use just use a bit of head bolt thread sealant. And like said, be damned sure you have the correct tolerance gasket for the adapter. ![]() J
White K20 |
#7 | |
I use Indian Head sealer on bolts going into oil passages
That's a new one. Isn't that low temp shellac type gasket material?
Works great on freeze plugs too
