08-04-2019, 09:22 AM | #1 |
1972 level rear with blocks or drop coils?
Have a stock 72 Cheyenne Super with stock suspension. Wanting to level the rear by lowering no more than 2". Truck has trailing arms. Not leaf springs. Is the best method drop coils or lowering blocks?
Thanks! |
08-04-2019, 01:07 PM | #2 |
Re: 1972 level rear with blocks or drop coils?
I would say lowering blocks if your coils are decent. Cutting, or replacing coils can be a hassle to get enough strength to carry a load, and ride decent. Others have used helper bags in addition to drop coils for the best of both.
08-04-2019, 01:13 PM | #3 |
Depends on how you plan to use the truck and the condition of your current coils.
72 C10 lwb fleetside -stock 350/350 combo |
08-04-2019, 01:35 PM | #4 |
It's just a show/driver truck.
08-04-2019, 01:55 PM | #5 |
Coils are the better way to go for a driver. Keep in mind, your current coils are probably worn and sagging, so new drop coils may raise the truck a bit until they settle.
08-04-2019, 02:13 PM | #6 |
Looks good as is.
08-04-2019, 02:15 PM | #7 |
For a driver lowering blocks are the better way to go as you maintain more of the factory range of suspension travel. This equates to better ride quality. It also maintains the factory shock angle which isn't great but it is still better than the angle on a truck with lowering springs. If you do go with springs look into a shock relocation modification too.
The downside of blocks would be a loss of ground clearance under the trailing arms.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-04-2019, 03:43 PM | #8 | |
BlahBlahBlah
That being said I would go with the blocks. A cheap way to see if its the look you really want.
08-04-2019, 03:54 PM | #9 | |
Can I still use the shocks that are on it now? Lowered a lot of trucks, but never a 67-72 with trailing arms. |
08-04-2019, 04:22 PM | #10 |
Either way you go the result will be the axle is no longer in the original position and you will have changes in the pinion and driveshaft angles which may of may not cause NVH issues
08-04-2019, 08:00 PM | #11 |
stock shocks with 1 or 2 inch lowering blocks should still be OK.
Look where the bottoms of your control arms are now, that will help you with the block decision. |
08-24-2019, 10:17 AM | #12 |
Follow-up Results: I installed 1 1/2" blocks under the trailing arms with longer U-bolts and the look is perfect and rides good.
08-24-2019, 10:56 AM | #13 |
Looks good! Where did you source your blocks? Thanks, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-24-2019, 11:03 AM | #14 |
BlahBlahBlah
Perfect, good job.
08-24-2019, 11:16 AM | #15 |
Looks sharp!
08-24-2019, 11:57 AM | #16 |
More better.....or is that...Super..More Better.....Beautiful truck red interior is extra sharp with a clean white truck.
08-24-2019, 12:54 PM | #17 |
Looks great! I need to do that to mine as well.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash 1972 SWB C-10 Highlander Blue/White 1972 Canadian 2wd Jimmy light olive 1970 SWB 4x4 4 speed 307 |
08-24-2019, 01:20 PM | #18 |
Bought blocks and u-bolt kit from Summit Racing. Item # WST 20415. Very straight forward job other than using 3 jacks and 2 com-a-longs.
