08-01-2019, 12:21 AM | #726 |
How did I get this OLD!
Re: What did you do to your truck today.The 3rd chapter
In the last few weeks I've transformed the bare bones farm truck into a CST
http://67-72chevytrucks.com/vboard/a...1&d=1564633085
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
08-01-2019, 06:40 AM | #727 |
New rim's and tires. Before and after
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
08-02-2019, 09:30 PM | #728 |
Replaced broken side mirror.CAUTION Work truck pictures ahead;
I was trying to tighten the mount and the stud broke at about 60 Ft.Lbs and almost broke my nose- did break my shades. This is the original mirror from the 60s I'm sure. The curved piece is SOLID steel with the ends turned down and threaded. Here is a picture of the original compared to the cheapo aftermarket replacement that did NOT hold the mirror in place at speed because the threaded insert was not staked in the tube. So I went to the local pick-your-part expecting to walk for miles but right there at the entrance was a nice 1978 with it's mirrors intact. Different style but at least it stays put in the wind. Added a spot mirror to the bottom. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
08-02-2019, 09:42 PM | #729 |
Rad
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
08-03-2019, 12:08 AM | #730 |
Received my new rear brake lines from Inline Tube for Raymond....PB Blaster, the proper tools & patience just doesn't overcome 47 years of rust
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
08-04-2019, 11:45 PM | #731 |
At the body shop.
Busy weekend.
New 4 row aluminum radiator from Summit. SUM-384018 had to notch the upper supports a little bit. And finally got the bedliner sprayed in my other moneypit.
" That didnt make it any newer " " Dont antique the equipment " |
08-05-2019, 07:58 AM | #732 |
A couple minor accomplishments over the weekend.
After a few days of soaking all the lines and nuts I got the mater cylinder and distribution block removed. Soaking all the bleeders and line connections at the wheels so I can hopefully blow out the lines before I install the new master. Sunday I thought I would quickly strip and prime one of the bed steps only do discover the finish goes in this order: clear, olive green metallic, mint green metallic, and primer. The greens and clear were laid on thick. After much sanding, blasting, and a bit of swearing I did get a quick coat of primer on the bare metal. Gotta come up with a better plan for the rest of the bed. |
08-05-2019, 03:20 PM | #733 |
Glove box project - finished getting the nice original stripped and primed - now ready for color...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-05-2019, 04:25 PM | #734 | |
laying low
08-05-2019, 06:01 PM | #735 |
Didnt work on it but bought a nice OEM gate for the stepper. The bottom looks like its bent laying on the table but it straight. Not dents just a little surface rust.
08-05-2019, 08:50 PM | #736 |
That's nice.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
08-07-2019, 08:53 PM | #737 |
Well I was thumbing thru many threads of these trucks running rough and found that the HEI trucks are gapper at 45. My truck had auto lite platinum gapped at 35 from PO that still looked new and clean. Swapped out with a.c. Delco 43s gapped at 45. Wow. Runs so smooth now. Even starts better.
1971 C20 Longhorn 350/350 "Conquistador" |
08-08-2019, 02:55 AM | #738 |
70+ ( Old Skool Club )
Neede a sheet of 4 x 8 plywood today so took the truck to Home Depot to get one.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-08-2019, 01:31 PM | #739 |
Got the tailgate down to bare metal time to weld up the tanneu cover holes that run along the top
08-08-2019, 02:50 PM | #740 |
All welded up .
08-08-2019, 03:34 PM | #741 |
Added Bumper Guards to the Shop Truck with the help of the "PTG Fur Baby Crew". LOL...……...........
08-08-2019, 04:49 PM | #742 |
Replaced the bed wood and strips
Mark, 1969 custom camper, 454,th400,373posi |
08-08-2019, 08:40 PM | #743 |
Proprietor of Dale's Corner
Goodness what a difference!! It looks great! Nice job......
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-08-2019, 09:39 PM | #744 |
Thanks first bed I’ve done, truck is a custom camper , 133 wheelbase, all I can say is man thats a lot of screws and patience is a virtue.
08-08-2019, 10:06 PM | #745 |
You could have bought that plywood in Tennessee, and hauled it home in that Cheyenne you know.
08-09-2019, 10:20 AM | #746 |
Finaly had some time to work on my escalating project
Striped the core support a few weeks ago Happy to see the trash bag sleeping bag prevented any surface rust Here are the before, during and after |
08-10-2019, 06:11 PM | #747 |
More bed work. Starting to take the old wood bed out. Wouldn’t be so bad but some PO decided tongue and grove wood with a crap pot full of carriage bolts was the answer. And drill holes in all the cross sills for the bolts. Hope the sills aren’t trash when I get this out.
Also started straightening, stripping, and painting the rear fender braces. I’ll have two good sets for my project with at least one set left over. Still have a couple to take off the drivers side fender. |
08-10-2019, 06:19 PM | #748 |
I've actually been in contact with the seller of the truck and have the spid pic.
08-10-2019, 06:22 PM | #749 |
At the body shop.
Got my new to me cluster dialed in.
The lens was crappy and made the chrome bezel look less than new. New lens new bezel my daughter repainted the needles.
08-10-2019, 08:33 PM | #750 |
1970 CST truck. The bed was really ugly and had a bunch of different colors of paint. Previous owner used the truck to haul house paint. Today my wife and I are applying Herculiner bed paint. Got the first coat on and it looks great, Gonna do the second coat in about an hour.
