08-09-2019, 10:04 AM | #1 |
4x10 speaker likes or dislikes ?
I picked up some stock corner speaker brackets and was wondering what speakers you use and do they perform that well . I,m not a boom boom kinda stereo guy but would like something good. Stereo shop says I wouldn,t be happy . He suggested 4 inch speakers instead running 2 per side but now that,s double the price 4 speakers instead of 2. I just like the clean look of the corner speaker brackets.I know someone here makes the 6x9 brackets but that would be another 100.00 to here in Can.
08-09-2019, 10:09 PM | #2 |
yeller
Re: 4x10 speaker likes or dislikes ?
I’m the one who sells the 6x9 and also 6.5 cab corner brackets. I can tell you both are leaps and bounds better sounding than than 4x10, and there are tons of speakers to choose from on the market. Yeah, you’ll spend some money, but you will be happy in the end.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
08-10-2019, 12:20 AM | #3 |
I have no time for this
Don’t waste your money on a 4”x10” speaker. Get the 6x9 brackets if you want cheap and loud, go with 6.5s if you want a good sound quality. There are tons of options in both sizes and even the cheapest in both will out perform the highest quality 4x10 speaker
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
08-10-2019, 06:32 AM | #4 |
I am using the same or similar OEM brackets with some 4x10s. If what you are after is a basic stereo setup, they work well. Don't remember what brand speakers I went with, bought them too many years ago. You will have less bass thump but in the small truck cab, usually not a problem. I did have adjust the rear cab wall out a bit to let the speaker magnet fit. A couple of well placed hammer blows did that. If you check before drilling your holes, probably could use some spacer washers instead. The OEM speakers those brackets were designed for lacked a bit in magnet size.
08-10-2019, 09:38 AM | #5 |
What ever size you decide on, pick a speaker with a high sensitivity rating (number). The higher the number the easier it is for the speaker to effectively convert power into sound.
08-10-2019, 08:45 PM | #6 | |
The sound of the 6x9's big different over 4x10's in bass and mid tones. Only about three choice of speaker for 4x10's.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
08-11-2019, 10:09 AM | #7 |
I love mine, using them with the Custom AutoSound Radio. I have tweeters in the A-pillars too. I think mine sounds fine, but I’m not blasting or thumping down the rode either.
Last pic is kind of dark, but I carpeted the cardboard tool tray and the speaker brackets. And then painted the speaker grille to match my color interior.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
08-12-2019, 10:27 AM | #8 |
thanks,all good ideas,now to choose
08-13-2019, 07:16 AM | #9 |
@bigblock73, would there be room on a corner bracket to put 2 6.5" speakers vertically in each corner bracket? it looks tight but it looks like it would almost fit.
08-14-2019, 11:23 AM | #10 | |
Cheap 6x9's sound better than the best 4x10's you can get (and there aren't many choices in a 4x10) |
08-14-2019, 11:58 AM | #11 |
I bought some 4x10 Boss speakers but had problem with only one side playing. I switched to 6x9 sony and did sound a lot better. I also had a small two way amp on both and bass was better on 6x9. I think a amp is a must to drive any good speaker IMO.
79 Chevy 2wd BIG10 350 TH400 |
08-14-2019, 02:13 PM | #12 | |
yeller
