Old 08-04-2019, 03:20 PM   #51
too much stuff
Roadtrip!
too much stuff's Avatar
Re: So when in 1972 did GM start installing single wall tops?
Pete, I will add to the thread and let you work your detective skills with the info from my blazers/jimmys.
Blazer 1, single wall top with a speaker grill on top of the dash.
Blazer 2 single wall with no speaker on top of dash.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-04-2019, 03:25 PM   #52
too much stuff
Roadtrip!
Wish I could be of more help, but this is what I have.
Jimmy 1, single wall top, no speaker.
Jimmy 2 double wall, no speaker.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 08-04-2019, 03:32 PM   #53
too much stuff
Roadtrip!
This will either help or just add to the confusion...
Jimmy 3, single wall, no speaker on top.
pic 3 is a jimmy I parted with a single wall top.
pic 4 is a body in storage and looks to have a double wall top, but not sure if it is original to it. (can't open the drivers door at the moment either.)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 08-04-2019, 08:37 PM   #54
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Eric thanks for posting. I’ll comb through these. I need to jog my memory regarding sequence numbers for GMCs - for some reason I seem to recall the sequence numbers differed and weren’t inline with Chevy but I may be mistaken.
Old 08-10-2019, 12:51 AM   #55
Gyrine
Active Member
My Blazer was built in Flint, sequence number 178459, has May dates in under the dash pad and on the NP205. Speaker is located in the dash.
Gyrine is online now   Reply With Quote
Old 08-11-2019, 10:13 PM   #56
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for posting. I ran into a guy with a 2wd Flint build 72 had an original single wall (that he swapped for a double wall) no speaker grill in the dash. Sequence was 126xxx
Old 09-08-2019, 10:57 PM   #57
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here’s another Flint built single wall without pickup style speaker grill atop dash so originally had a speaker beneath the dash. December 1971 build.
Thanks Eric.
Old 11-05-2019, 07:12 PM   #58
1mrtimk
1972 St Louis built 168756!
Speaker under dash and black double wall top when I bought it!
Owned since 1980 with no reason to believe it was not original.
Replaced it with a single wall many years ago.
1mrtimk is offline   Reply With Quote
Old 11-08-2019, 03:01 PM   #59
MJN
MJN's Avatar
I'll dig up some old photos before selling it- was a '72 St. Louis built with double wall top. Actually Mudduck74 bought it but I haven't seen it since.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 11-12-2019, 08:41 AM   #60
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by A1971Blazer View Post
One must bear in mind that the assembly of vehicles was much different back in '72 than it is today..
'72 marked the end of the body style for the trucks and the Blazers....
perhaps in an effort to use up the current inventory of parts.....some Blazers got truck dashes with the speaker grill in them and some did not....
maybe the same with the tops...they didn't want to be stuck with a warehouse full of unused tops....
simply due to availability....with no rhyme or reason? IDK....just guessing...?
There’s definitely a pattern and it’s documented on this thread. Flint switched from double to single walls and the early single walls used the non-pickup, external to the dash speaker whereas later run single wall tops used the pickup style speaker. Makes sense to switch to the pickup style in terms of stock but St Louis doesn’t appear to have followed suit and there’s no definite evidence of St Louis using single wall tops.
What I’d like to know is when St Louis stopped making the 72 Blazer relative to Flint. Flint assembled them until at least May of 72 and probably later. I’m not sure about St Louis.
Old 11-12-2019, 07:41 PM   #61
69-72
69-72's Avatar
72 2wd GMC built in Flint on March 14th 1972 Single wall no speaker
72 4wd Chev built in Flint May 1972 Single wall yes speaker
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 11-13-2019, 08:43 AM   #62
DeadheadNM
Carpe manana
DeadheadNM's Avatar
All 72 K5s had provisions for both top styles
Old 11-13-2019, 07:41 PM   #63
69-72
69-72's Avatar
Id have to check my Blazer but my 72 Jimmy definitely only had holes for a single wall
Old 11-14-2019, 09:44 PM   #64
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Post pics up if poss. Would be great to see top and bottom shots. Thanks.
The LH rear quarter on my Blazer was replaced with a GM replacement that was not pulled from another K5. It was new but GM. It has provisions for both tops.
Old 11-17-2019, 10:32 PM   #65
FarmTruckGarage
FarmTruckGarage's Avatar
I have a 72 I just bought a couple months ago from Las Vegas. I live in MI. It only has holes for a single wall top. Fortunately I was able to scrape the paint off my door sticker. No speaker hole in dash but looks like theres a mount for one.
Sorry spid is upside down... not sure why it flipped
FarmTruckGarage is offline   Reply With Quote
Old 11-17-2019, 11:00 PM   #66
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks so much for posting. Interesting twist of information. Would love to see more examples. No sign then that the double wall holes were filled in?
Old 11-18-2019, 07:56 AM   #67
FarmTruckGarage
No signs at all. As far as I can tell the quarters are original. Unfortunately I don’t have a single wall for it right now. I have 2 doubles.
Old 11-18-2019, 03:39 PM   #68
mister.freeze
mister.freeze's Avatar
my '72 (St. Louis) has both sets of holes and a double wall. the single-wall holes are 'sorta' filled in.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 11-18-2019, 08:46 PM   #69
1mrtimk
Also, single and double wall holes!
Old 11-19-2019, 10:46 AM   #70
mister.freeze
Mine is 165182, so yours is later than mine. Maybe more serial numbers will pin down a better date?
Old 11-25-2019, 01:37 AM   #71
Hagendog
72 with single wall top
Hagendog is offline   Reply With Quote
Old 11-25-2019, 10:16 PM   #72
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for posting.
Old 12-01-2019, 03:57 PM   #73
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here’s a photo from 1rippen76 that shows the difference between CST and non-CST single wall top to bedside strips. There are two styles each with LH and RH specificity.
Old 12-01-2019, 07:28 PM   #74
Hagendog
Are the ones on the left the CST? Those are the ones I have
Old 12-01-2019, 10:27 PM   #75
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Correct. These clear the chrome trim that secures the top of the rear panels.
