Old 08-23-2019, 02:21 PM   #26
lukeembry
Originally Posted by SCOTI View Post
I looked @ your build thread on LS1.com. Kind of figured you were going bigger than the L83 since you already had a 6.0.
I highly recommend swapping out your rag-joint set-up for a Cherokee XJ shaft swap. I chimed in on pg.2: http://67-72chevytrucks.com/vboard/s...=505196&page=3
The L83 actually makes more power than a stock 6.0. I’m looking for a modern driver so 400hp is plenty. No rag joint on this truck, I made a steering shaft I’ll post pics on ls1tech
lukeembry is offline   Reply With Quote
Old 08-23-2019, 04:46 PM   #27
SCOTI
SCOTI's Avatar
Re: 85 C10 LT/6L80 Frame off build
Gotcha. The pics I saw over there it had what looked like a fresh rag-joint in place on that new Lee box. Seems you're farther ahead on the build than that pic.
Anyhoo…. I figured I would say something since you spent the money for a better box
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-23-2019, 06:21 PM   #28
lukeembry
Yea I went back and forth on what I wanted to do. Finally decided on building a shaft. I’m behind posting pics and updates, I’ll add some updates this weekend. Keep in touch
Old 08-26-2019, 01:06 PM   #29
Jalaska907
Great Build! Im trying to get motivate on my 86 right now. Im currently working on my mopar. Im a huge fan of Tamco products, been using them for 5/6 years now. My challenger is ground up Tamco, and has been painted for two years now. Still looks like the day it was shot.
Like many have said before, killer build, and Im looking forward to watching it come together.
Jalaska907 is offline   Reply With Quote
Old 08-26-2019, 07:51 PM   #30
nekkidhillbilly
I feel like im watching hgtv when they bust up perfectly good cabinets with a sledge hammer. just messing with ya.
2004 2500 hd dmax cc 4x4
2008 saturn aura xr
1966 buick gran sport
1984 k20
nekkidhillbilly is offline   Reply With Quote
Old 08-27-2019, 12:00 AM   #31
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I've done a few l83 swaps and drive my 87 gen 5 swap a few times week and daum fun. If you dont have a high hump trans tunnel, you will need one.. the 6l80 is not going to fit a low hump tunnel. See my build thread in the ls swap sectupn
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-27-2019, 07:23 PM   #32
rickit
rickit's Avatar
looking good there neighbor!
rickit is offline   Reply With Quote
Old 08-28-2019, 10:15 AM   #33
lukeembry
I raised the tunnel some to clear
Old 08-28-2019, 10:15 AM   #34
lukeembry
Tammy and the Tamco group are awesome people, I really like their products
Old 11-19-2019, 11:35 AM   #35
lukeembry
Here's a few pics of the build, going to try to find time to give updates every couple days. Holley LT mid-mount accessory drive looks right at home. using a 87 R10 hanger I added a Walbro 255 pump along with a Holley Hydramat. I'll be using dual tanks that aren't baffled from Holley, they come silver but I went ahead and painted them again and used a flat clear to finish them off.
Old 11-19-2019, 11:37 AM   #36
lukeembry
Engine bay looking more complete, inside of bed panels stripped down from having bedliner spray for years and last is some of the hardware back from zinc plating.
Old 11-19-2019, 11:56 AM   #37
SCOTI
SCOTI's Avatar
I like the color more & more w/each view. Coming together nicely!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2019, 11:19 AM   #38
lukeembry
Master Power Brakes installed, very nice brake kit and highly recommend, designed to use CPP spindle but I changed to the Wilwood spindle for wheel fitment issues. I'll also be using the Baer remaster with custom built stainless lines.
Old 11-21-2019, 11:23 AM   #39
lukeembry
Budnik wheels are ready for tires, I'll be running 20x10.5 and 20x8.5 with Michelin tires. I really like the brushed centers with polished lips.
Old 11-21-2019, 11:33 AM   #40
TKCR
TKCR's Avatar
Nice!
Old 11-21-2019, 12:11 PM   #41
SCOTI
SCOTI's Avatar
Nice. I would only make three small changes......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2019, 02:21 PM   #42
Shifty One
Shifty One's Avatar
Gorgeous!
Old 11-21-2019, 03:07 PM   #43
lukeembry
new bed floor, reworked OE wheel tubs and new front panel. it was a tough choice to finish the inside of the bed out nice vs bedliner. I really hate that I can't put anything back there without scratches or damage.
Old 11-21-2019, 03:53 PM   #44
SCOTI
SCOTI's Avatar
Standard rubber bed matt when needed should help w/that.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2019, 04:01 PM   #45
lukeembry
id like one but they quit making short bed matts years ago, I guess I could pick up a long bed mat and cut it to fit.
Old 11-21-2019, 04:04 PM   #46
SCOTI
SCOTI's Avatar
Exactly. It's not like it would be there full time but sure is a nice layer of protection if/when needed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2019, 06:03 PM   #47
focusedontheprize
focusedontheprize's Avatar
Progress looks great!
focusedontheprize is offline   Reply With Quote
Old 11-21-2019, 09:51 PM   #48
MHarvey
Hey Luke, would you want to sell your old bed floor? I’m working on mine as we speak and my bed floor needs some repair. I was going to line it anyway, so thought I’d see if you wanted to part with your old one. I’m in Bowling Green, so local to you. Crazy to see the transformation that you’re going through on this truck. I’ve seen it around town over the years and always thought it looked great. Thanks, Mike.
MHarvey is offline   Reply With Quote
Old 11-22-2019, 09:16 AM   #49
lukeembry
Mike you just missed out, i gave it away last week. after posting it forsale a few times and no bites i gave it away to clean up my shop. if you need any other parts let me know, i still have alot of stuff.
Old 11-22-2019, 09:22 AM   #50
MHarvey
Thanks Luke, I appreciate it. I’ve been so off again/on again with mine that I haven’t kept my eyes open for certain stuff and I seem to miss out. Your truck is looking great, keep up the good work!
