08-16-2019, 12:01 PM | #201 |
Re: 1987 R10...aka Belushi
I’m also contemplating putting a serpentine setup on Belushi to downsize the clutter on the front of the motor.
08-17-2019, 06:18 AM | #202 | |
Desert |
08-17-2019, 09:54 AM | #203 |
Amazon. Just search ‘DVL2 latch’ and it’ll be the 2nd or 3rd result.
08-20-2019, 08:50 PM | #206 |
Looks good
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
08-21-2019, 07:32 PM | #207 |
Thanks Tina!
I also decided to clean, polish & wash the underside of the hood and install new hood insulation. |
08-21-2019, 08:30 PM | #208 |
I also decided to install the rear wall carpet piece. I don’t really care for it, but maybe the little extra insulation factor will make it quieter inside?
08-21-2019, 09:13 PM | #209 |
I like both. I went with something a little different. I saw this and wanted it ever since. Got it after the OEM hood was painted.
I had the cardboard tool tray, but I carpeted over it. It seemed like it made the cardboard tray a bit more durable.
08-25-2019, 07:17 PM | #210 |
I ordered up an Eaton posi and an aluminum diff cover today. Hopefully, I get them installed next weekend.
08-29-2019, 07:48 PM | #211 |
Got the posi, diff cover...& a matching set of valve covers. I’ll start the install of everything this weekend. Hopefully, I’ll be laying down two fat black lines by Sunday.
08-30-2019, 09:29 AM | #212 |
Is that carpet 'wall' from the supplier or just bulk material that you made work? Fit looks nice.
08-30-2019, 10:06 AM | #213 |
It’s made by ACC. It does fit pretty well, cleaned up the back wall and it did seem to quiet down the exhaust note when sitting still. Oh, and it was relatively inexpensive and easy to install.
09-01-2019, 01:45 PM | #214 |
Well, I ended up with a pretty serious mishap. My differential that I ordered showed up, but.... It is the wrong one. Unfortunately, I didn’t get the differential until after I’d disassembled the rearend. The packing list says it’s for an 8.5”, but the new differential is an 8.2”. I’m dead in the water
09-01-2019, 02:04 PM | #215 |
Well, it just keeps getting better... NOT. Pulled the new valve covers out of the box and...
Time for the pool and |
09-01-2019, 02:26 PM | #216 |
looks like some of my luck is finally rubbing off on you....
09-01-2019, 02:48 PM | #217 | |
Worst part is that the lift is tied up until I get the diff installed. I was going to get the diff in today and then get started on swapping out the transmission in Martha tomorrow... |
09-02-2019, 10:20 AM | #218 |
Just so I can always confirm it has a 3.73 in it. Part # on the ring gear is 26035826 11-41 GMK. 41/11=3.727
09-03-2019, 09:50 AM | #219 |
nice truck! just curious what size 18" tire your running? I have a similar set of ridlers. thanks! Russ
09-03-2019, 10:39 AM | #220 |
I’m running Toyo Proxes ST II’s. Fronts are 18x8 with 255/50r18 and rears are 18x9.5” with 295/45r18’s.
09-03-2019, 04:41 PM | #222 |
They are shipping a Yukon Duragrip posi next day air and giving me a substantial refund due to time lost.
09-04-2019, 12:25 PM | #223 |
That helps.
09-04-2019, 08:31 PM | #224 |
Yes it does!
Well, it did show up as promised and It’s the correct part. But I have my Falcon on the lift because I’ve got to get the trans pulled out of it. Hopefully I’ll finish pulling it tomorrow night after work. Then I’ll start back on Belushi. To many PROJECTS!!! |
09-05-2019, 10:50 PM | #225 |
I couldn’t STAND it. So I finished up installing the diff tonight. Ended up having to ‘shim’ up the pinion a tiny bit as it was a bit sloppy (&it needed a new seal anyway). It is quiet as a mouse, but no more right tire spin from a stop. I didn’t do any touch up painting as I was just amped up to get it back running, but here’s a shot. I promise that I’m going to clean it up paint the housing this weekend
