Old 07-16-2019, 12:16 AM   #101
Scurry67
Re: 67 SWB First Build
Dang tailgate is taking longer than I figured. Had an hour this weekend to cut out the handle relocate. I was hoping that the kit I bought would be a flush mounted patch but turns out it is meant to bolt in. Will possibly try to modify it or at a minimum weld it in instead of using the bolts.
Bow is definitely less noticable than before.
Handle relocate cutout.
New handle location. Also a few small patches I need to finish welding from needing access with hammer and dolly.
Goal is to get this and my floor in some primer by end of summer. I'll hopefully be done working out of town by then and have more shop time
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 07-16-2019, 01:36 PM   #102
TA_C10
TA_C10's Avatar
All this work is going to pay off. That tailgate is looking good sir. Interested to see how you deal with the bolt in handle relocate.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 07-17-2019, 12:55 AM   #103
Getter-Done
Getter-Done's Avatar
Great progress on the Tail-gate.
Thanks for all the pictures.
It is looking good.
84 Chevy K-20
Old 07-29-2019, 08:01 AM   #104
clay68c10
clay68c10's Avatar
It’s looking good! All that blocking time spent will definitely show when it’s shiny.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-05-2019, 09:11 AM   #105
Scurry67
I hope so. Plenty more to come!
67 SWB First Build
Old 08-05-2019, 09:20 AM   #106
Scurry67
Friday night I finished up welding the tailgate holes. Spent Saturday morning getting everything prepped and then spraying primer for the tailgate and cab floor. Had to spend a little time with the DA getting rid of some surface rust.
Tailgate prepped for primer.
Floor in primer. Will eventually get a sound deadener installed. Next is to flip the cab.
Tailgate in primer. Pretty sure I'm going to bolt the handle relocate in.
Misc. Items
Starting slinging mud on the tailgate. Fingers crossed all that effort will show at the end.
Ran out of time to make a lot of progress. Hopeful to hit it hard the next couple of weekends.
67 SWB First Build
Old 08-05-2019, 11:06 AM   #107
TA_C10
TA_C10's Avatar
Looks good!
"It's only money".
Old 09-05-2019, 12:47 AM   #108
Scurry67
Not a lot of progress. Finally moved back home after an out of town job for work all summer. It's been a busy week back getting caught up on things a neglected around the house. Managed to squeeze an hour in the shop here and there. Finished with the body filler and now onto the skim coat and 80grit.
Still can't believe I have been working on the dang tailgate for over 6 months
67 SWB First Build
Old 09-05-2019, 09:25 AM   #109
cornerstone
cornerstone's Avatar
Priorities suck. If we could just turn into selfish jackwagons I bet we would have our trucks finished within a month.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 09-05-2019, 11:42 AM   #110
TA_C10
TA_C10's Avatar
Ouch, I feel like a selfish jackwagon lol. Well maybe not that bad. My wife is dealing with a lot right now. She will be getting a vacation when I finish my truck to say the least . That tailgate is gonna be sweet when you finish scurry. Can't wait to see it done!
"It's only money".
Old 09-13-2019, 07:53 PM   #111
kev2809
low n' slo
kev2809's Avatar
nice work!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is online now   Reply With Quote
Old 09-21-2019, 03:20 AM   #112
Scurry67
I decided it was time to switch gears. The tailgate still needs some work. It's far from perfect, but hopefully it'll do the job.
Set the tailgate aside and started mudding my driver door. I got it roughed in for the time being. I won't finish it up until I hang the doors again.
Last weekend I had some buddies over and took advantage of it. I had them help me flip the cab onto the firewall. From there I started cleaning up the bottom of the cab. I had some random pin holes to fill from when I was doing floor patches. Also removed some old seam sealer where the floor pan overlaps the firewall. New seam sealer went in right behind it after it was cleaned up. Welded up driver rocker/cab corner as well.
The previous cab owner welded up the bench seat frame holes and had used a different seat. I plan on using a bench seat from a 68, so I was able to remove the welds and run a thread cutter through the bracket nuts to get it cleaned up and functional again.
Lastly, I put a couple coats of epoxy primer on it. I realize it's not perfect and my welded seams standout. I figure it won't matter too much because it'll never really be looked at. I'll throw some undercoating on later this weekend or early next week before I get the cab flipped back over. That should help mask the weld seams.
Tailgate with glaze sanded with 80grit
Cleaned up the shop to switch gears. Need to get cab done so I can start working on the frame this winter
Buddies helped flip cab
Prepped the cab for epoxy primer.
67 SWB First Build
Old 09-21-2019, 03:26 AM   #113
Scurry67
Seam sealer installed.
All primed up! Undercoating to follow.
67 SWB First Build
Old 09-21-2019, 05:43 PM   #114
Scurry67
Undercoated. Try to get it flipped back upright this week to finish up the doors.
67 SWB First Build
Old 09-21-2019, 11:55 PM   #115
TA_C10
TA_C10's Avatar
Ah man, no lizard skin?? I'm just kidding, looks great. How did that sem brand undercoating do?
"It's only money".
Old 09-22-2019, 12:32 AM   #116
Getter-Done
A+ great work.
Does that undercoat mask the welds like you wanted?
I want to know. Because the floor pan I purchased re-stamped
need a little cover up or reweld.
Your floor-pan work looks Good.
84 Chevy K-20
Old 09-29-2019, 11:27 PM   #117
Scurry67
I know... I do plan on using it on the interior. This stuff worked pretty good. Seams pretty tough and is supposed to help with sound.
Didn't you use lizard skin? How much would you recommend I'll need for the interior of the cab?
67 SWB First Build
Old 09-29-2019, 11:31 PM   #118
Scurry67
Originally Posted by Getter-Done View Post
A+ great work.
It covered them up alright. I could have done a bit more grinding but I was getting ancy to get it coated
67 SWB First Build
Old 09-29-2019, 11:41 PM   #119
Scurry67
Was able to spend a little time in the shop this weekend. My brother and I did some brewing in Friday. Afterwards he helped me flip my cab back.
Spent yesterday night hanging the doors and slinging some mud. I'm liking the looks of the gaps so far. Will hopefully finish the last of the glaze on the doors and cab by the end of the week.
67 SWB First Build
Old 09-29-2019, 11:45 PM   #120
Scurry67
Also got my engine block back out. Cleaned up the little bit of surface rust and started gathering all the goods. Going to take the crank, pistons and rods to an engine shop to get them balanced in the next week or two.
67 SWB First Build
Old 09-30-2019, 06:24 AM   #121
TA_C10
TA_C10's Avatar
1 gallon got me 3 coats underneath cab and 3 coats inside cab. On the inside I shot it up the firewall to underside of dash, and all the way up the back of cab. I shot it in the cab corners too way down inside and all the way up. And all this with the gun nozzle almost all the way out spraying the most material.
So 1/2 a gallon would be enough for inside your truck if they sell that size.
Looking good seeing those doors go back on. I'm finishing my cab right now about to spray it soon. Ready to see the doors go back on too....
"It's only money".
Old 10-07-2019, 09:55 PM   #122
Scurry67
Pulled the trigger on the lizard skin. Should be here later this week. Planning on doing the floor and inside the doors. Thanks for the qty 👌🏽
67 SWB First Build
Old 10-07-2019, 10:10 PM   #123
Scurry67
Waiting on supplies to come in this week to finish the interior floor for the sound deadener. Also need to get my flywheel to get the engine components balanced.
I continued on the sanding of doors. Looking pretty solid. I'll probably have my dad up for a day some weekend to 100% the cab for polyester primer. Hopefully sooner rather than later.
Decided to get going on my grill. I had two 67/68 grills, one was in a bit better condition than the other. I've seen on other projects where the rivets are removed for the parking light frame in the grill and swapped out for the smooth frame. I'm going to give it a go!
67 SWB First Build
Old 10-07-2019, 10:27 PM   #124
Getter-Done
That sounds like a good plan.
I haven't noticed this process.
I know you will take good pictures of this.
Looking Great
84 Chevy K-20
Old 10-13-2019, 06:16 PM   #125
Scurry67
Little more progress in the right direction. Lizard skin came in this week so I spent time prepping the cab floor. Put two coats on the floor and ran it up the firewall and back. I bought the paint gun for it and it sprayed real nice. Easy to clean up too. Finished up the ceramic coat today. Overall the whole process was pretty simple. Hope it works like it's supposed to!
Finished stripping the grill and its components. Also did the same thing for the cowl panel. Cleaned up the rust on the backsides and applied por 15. Today i through down a couple coats of epoxy primer on them.
Sound deadener sprayed on floor and firewall
Ran it up the back
Finished off with ceramic coating next day
Por-15 on back of grill and components
67 SWB First Build
