Old 09-05-2019, 08:11 PM   #1
Reese Allen
Identifying rear diff on 1980 C20. LSD or not?
My truck has a 14-bolt rear differential. I've removed the cover and drained the oil, and am about ready to button it all back up and refill with fresh oil. However, I can't figure out if this truck has an LSD or not, and therefore whether to add LSD additive into the oil.
Picture: https://imgur.com/VLqjWER
With the rear end jacked up, and transmission in neutral, when I spin one wheel, the other stays stationary. But if I put in gear and spin one wheel, the other spins the other way.
I'm inclined to think this means it does NOT have an LSD, but I'm getting so much conflicting information after searching extensively that I am not feeling very confident about this. Help?
Reese Allen is offline   Reply With Quote
Old 09-05-2019, 08:45 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Identifying rear diff on 1980 C20. LSD or not?
The diff described and pictured is not an LSD...it is an open or standard diff...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 09-05-2019, 09:21 PM   #3
sweetk30
sweetk30's Avatar
4 windows and see spider gears = open
4 windows and see coil spring and block of steel = detroit locker ........... do NOT pull apart a detroit type unit unless you bolt the unit together inside or it will pop open good on you and might hurt .
3 pins on the center of case were the ring gear bolts and no windows = gov-loc posi unit .
3 pics in order as i typed above .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-05-2019, 09:46 PM   #4
mongocanfly
mongocanfly's Avatar
("3 pins on the center of case were the ring gear bolts and no windows = gov-loc posi unit .")
what k30 posted is what you have.....G80
it is not a open diff..it the GM version of a posi
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-06-2019, 10:18 AM   #5
sweetk30
sweetk30's Avatar
forgot to add also . the strongest of the gov-loc posi units is the 14ff . i have run them stock to built 400 sbc engines with 38" tall super swamper mud tires and no problems .
Old 09-06-2019, 03:12 PM   #6
Reese Allen
This is helpful. Mine looks just like the first one. Four windows with small gears visible through them. So I assume this is an open diff and therefore I shouldn't put anything but gear oil into it.
Here's a better pic, you can see one of the windows and small gears: https://imgur.com/a/7u0Z6Hv
Old 09-06-2019, 04:52 PM   #7
mongocanfly
I think i see the windows now...so that changes my opinion...couldn't see them in the other pic...looks open
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-06-2019, 05:49 PM   #8
sweetk30
sweetk30's Avatar
open diff or gov-lov both call for std gear oil in these axles .
and yes you have open diff .
