#76 |
![]() Join Date: Dec 2009
Re: 67 (Crew Cab) C30
A little more progress.
The Person that normally does my sand blasting is Booked Up. So that leaves it to ( You know who) ![]() It was close to sunset on the next 2 Pictures. Better than No Pics??? .
#77 |
My Hired help seems to be on Vaca-tion
![]() Here is a picture of under the dash after sandblasting and primer. .
#78 |
Quick update.
I got the cab divided. I will post more pictures. .
#79 |
Couple more pics.
#80 |
Got the front part of the (top)roof skin removed.
I was a little rusty at the seam. .
#81 |
There was (mouse nest) insulation all across the front on the roof seam.
At first I though mice? It was neatly placed all the way across the front channel. So this is what the factory done to hold the cab light wire in place and protect it. Because some of it was still bonded to the wiring harness. Driver's side sunvisor reinforcement plate and hole for routing cab light harness. Pass. side sunvisor reinforcement is there so A visor could be added. Because this truck didn't come out with one. This is the last terminal on the cab light harness. Here's a picture of the Insulation from pass side view. .
#82 |
I have got a little more done.
I will catch up with my pictures & progress. I am cleaning up from when I cut the roof off. Drivers side B-Pillar Top view inside dome light. I am removing the excess piece by piece to keep my back panel in the best condition. .
#83 |
I used a grinder and a home made chisel and took my time to remove the spot welds of the excess of where I cut the roof panel out. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 09-23-2019 at 10:42 PM. |
#84 |
Pass. side clean up of roof removal
Center Driver's Side .
#85 |
Here is a small update.
After splitting (di-sec-ting) the cab Got the cab sand blasted. Then primed. More pictures soon. . .
#86 |
A few more pictures.
Fresh out of the sand blast place. Back of the cab Right side (under the dash) Left side (under the dash) .
#87 |
Got it Primed
Left side (back of cab) Ride side (back of cab) Top view from Drivers side .
#88 |
![]() Join Date: Apr 2008
Good progress, building it right
71 C10 72 K20 72 K10 Super Kirk |
#89 |
My next step is a (Frame) jig for the floor-pans. I need to drill holes in that frame then level it. .
#90 |
![]() Join Date: Nov 2018
Are you meaning make a jig to put your body mounts on the frame?
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#91 | |
I am in the process of making a Platform for the cab. When I complete it I will take Pictures. This platform is to build the cab. I am making this platform using 8" I beam for my base. I will have stands for the different measurements with the floor-pan braces that it will take to make the differences in the mounting points in my Floor-pan. This is how I will transfer the floor-pan to my frame and cab mount locations. .
#92 |
Small update.
My helping hand is getting a little sassy. Got some work done on the platform. This is the frame I will build my cab on. I leveled and welded the 2 I-Beams. Check Both I-Beams for square in X & Y & Z. .
#93 |
![]() Join Date: Aug 2004
That’s one hell of a platform! I like it. You could also use it to do any frame work needed.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#94 | |
I hope to get some more work done to the frame today. .
#95 |
Added Trailer hitch to my Platform.
This will be used to build the cab. My helper is asleep at the wheel ![]() Welding the hitch on the trailer 1 2 3 Finished and Now My Helper is Awake ![]() I will get picture's of this frame in the day-light later on. She must be a Night - Shift dog ![]() .
#96 |
Update.
#97 |
I got the 2 floor pans mated together for some measurements. . . .
#98 |
Progress report.
![]() After All the Holiday party's ![]() I am Glad to spend time with the family ![]() I just wish they liked Trucks like I do. ![]() I cut Circle's out of a sheet of steel I welded those to the top and bottom of a piece of pipe to make some stands for leveling the floor pan. I didn't take a Picture of the pipe before I started cutting ![]() This pipe that I used was the pipe that was my basketball pole when I was young. Yea I saved it that long. ![]() I turned these on the lathe. Then put them on the mill to get them close to size. I then had them Precision ground to the (height) +/- frame mounts / jig frame. These are the test fixtures. ![]() These will be used on my platform. .
#99 |
Then the Next step is the
![]() Solid stands I have machined in the 3rd and 4th picture. I will get the floor-pans leveled with the pipe stands in the 1st and 2nd picture below. Then I will know the Difference between the front and Rear stand measurements. These (solid) stands in the pictures below are on stand -By for now ![]() Once I get the floor-pans level. I will know the measurement to grind these stands in the pictures below. . .
#100 |
Wow, impressive! How much does your helper get paid per hour?
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
