09-11-2019, 10:57 PM | #1 |
Growling Noise in 2004 Silverado Right Dash Area
Sounds like it might be the blower motor for the A/C, but only happens after a dead stop and then start rolling. A bad bearing would make noise all the time, seems like. Thanks for tips, LBJ
09-15-2019, 08:28 AM | #2 |
Re: Growling Noise in 2004 Silverado Right Dash Area
Still growling! It's too deep a growl to be the blower motor. It really sounds like the tire rubbing on a fender but it happens going straight down the road. Guess I'll ride it out till whatever it is totally fails. Ha
09-15-2019, 12:10 PM | #3 |
Moderator
Does it change with the road speed or is it just a constant one note drone.
The blower would change with the fan speed. A tire rubbing would be obvious from the clean rubbed stripe on the tire after a few mile trip on blacktop.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
09-15-2019, 12:53 PM | #4 |
Have you checked the front brake pads lately?
Just a thought ? .
09-15-2019, 02:11 PM | #5 |
how many miles?
2wd or 4wd? recent repair history of components in this area? isolated noise to under chassis, under hood or in cab yet?
I started out with nothing - and I still have most of it |
09-15-2019, 02:53 PM | #6 |
Quick answers, haven't seen any marks on the tire.
Seems to be the same noise. No change. 95K miles, 4WD. Had the A/C system recharged several months ago due to a leaking charge access valve. No other work on the truck lately. Since it only happens while I'm driving, and only lasts a few seconds, haven't isolated it further than coming from behind the right dash. Brakes haven't been touched since brand new. I've checked them and they are still good. But obviously, with only 95K miles in 15 years, I'm not that hard on brakes and vehicles. Thanks all! LBJ |
09-15-2019, 07:05 PM | #7 |
Moderator
Just spitballing here...
Try to change the fan speed when it's making noise. If it's the blower it'll change pitch. If the AC is slightly low on refrigerant you could be hearing bubbles in the evaporator. The blend motors get clikety clackety when the gears get dodgy but they get really obnoxious and stay that way.
09-15-2019, 08:01 PM | #8 |
Hatzie, I'll try to change the blower motor speed next time. It happens intermittently. Cannot predict when it will happen. I changed the blend motor earlier this year, for the driver's side, anway. I had the freon recharged and it seems to be holding as the A/C stays pretty cold. the mechanic changed out a cheesy GM part that goes bad on many GM cars. He replaced it with an aftermarket brass fitting that also had a Schrader valve.
09-15-2019, 09:45 PM | #9 |
Moderator
Wildly intermittent faults are a bunch of fun to track down ain't they. Almost as much fun as a root canal.
Only thing you can do is wait for it. It has to be acting up to find it.
09-16-2019, 01:50 AM | #10 |
hmm, intermittent and still not sure where sound emanates from but sounds like in dash area..
possibly either of these? mode door actuator just above and right accelerator pedal, just replaced mine couple of weeks ago.. it was growling because it was running over travel limits and slipping inside the sector, eventually failed to defrost vents only.. temp blend door actuator under/behind glove box, mine is thumping now so probably next.. actuators can change sounds due to slight voltage variances between idle and off idle engine rpm.. my '02 has 190k on it and the windows raise a little faster with some throttle btw, if you end up needing to replace this actuator, DO NOT follow the idiots on youtube.. I could not find one single tutorial that explained the r&r correctly and figured it out by myself.. pm me if you end up needing assistance.. there's a little trick to getting the cam followers lined up in their grooves on that sector that was not posted anywhere on the internet I could find.. ACDelco 15-73952 GM Original Equipment Heating and Air Conditioning Panel Mode Door Actuator
09-16-2019, 09:03 AM | #11 |
Killer Bee, I replaced the door motor for the driver's side last year, or so. I think I might have read your comments on how to to do that one right. It's still working fine, but maybe it's the one on the passenger side.
I wouldn't have made a good professional mechanic. My method of repair is wait till it breaks down, then fix it! ha. Diagnosing what's wrong is the hard part - fixing it is easy. Thanks, LBJ PS. I looked at that link on Amazon. One post said he thought he ordered a "genuine" AC Delco part for $49 and got a "made in Korea" part he could have bought elsewhere for $20. Ha. I order these parts from Rock Auto. If they say its Delco, it's Delco. Plus they usually have several alternative manufacturers to pick from. My 2 cents. Last edited by LBJ; 09-16-2019 at 09:11 AM. |
