Old 07-23-2019, 05:26 PM   #251
Evldoer
Re: lowered shortbeds on stock wheels?
3/5 drop
Evldoer is offline   Reply With Quote
Old 07-23-2019, 06:54 PM   #252
sweetk30
sweetk30's Avatar
85 thats 90% done final assembly.
5.3 / 4l60-e 12 bolt rear / 2.5" spindles front and 2" hanger rear and 1" longer shackle rear for total of 2.5 . still has stock rake but lower . rollers are 88-98 sport rims and 31" tires for now . going 255/70/15 on 15x8 ralley unless i find some cool old school aluminum's . front bumper swap to 4wd air dam no tow hook cut outs for a 1.5" lower look over the 2wd air dam .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-24-2019, 07:59 AM   #253
RWJJR
RWJJR's Avatar
Lowered with 2.5" Western Chassis spindles in front (stock coils) and 4" in rear with dearched springs. 15x8 rallys in front with 235/70/15 and 15x8 rallys in back with 275/60/15......almost stock wheels lol!
1980 Silverado short bed
1993 GMC 1500 LS swap
2006 Lifted Z71 Crew Cab
RWJJR is offline   Reply With Quote
Old 07-24-2019, 12:00 PM   #254
62 Longbed
62 Longbed's Avatar
Just got mine back on the road ..
62 Longbed is offline   Reply With Quote
Old 07-24-2019, 04:08 PM   #255
SCOTI
SCOTI's Avatar
Nice.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-29-2019, 10:05 AM   #256
Dads79GMC
Dads79GMC's Avatar
Here you go.
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 07-30-2019, 10:48 AM   #257
nlped
nlped's Avatar
Before the wheel change with the factory aluminum wheels.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-01-2019, 05:45 PM   #258
mikentosh
mikentosh's Avatar
Here’s my ‘77 lowered with 2” spindles + 2.5” springs and flipped in the rear with stock 3 pack leafs. It’s on 15x8 fronts with 245/60R15s and 15x10 rears with 275/60R15s
mikentosh is offline   Reply With Quote
Old 09-01-2019, 08:09 PM   #259
nlped
nlped's Avatar
With the 18’s.
Carter
Old 09-02-2019, 11:36 AM   #260
SCOTI
SCOTI's Avatar
Nailed it! Timeless right there.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-03-2019, 06:38 PM   #261
stomper
Junior Member
stomper's Avatar
78 Sierra. Original owner's son said it never spent a night under cover.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Gold White Fleetsides/Saddle
stomper is offline   Reply With Quote
Old 09-16-2019, 11:20 AM   #262
badfarmtruck
my daily
btw no bags
badfarmtruck is offline   Reply With Quote
Old 09-16-2019, 12:16 PM   #263
SCOTI
SCOTI's Avatar
Originally Posted by badfarmtruck View Post
my daily
btw no bags
Good looking truck!
It will be asked: How was the drop done? What are your parts specs/tech info?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2019, 12:38 PM   #264
badfarmtruck
front:
3" spindles
1 coil cut off stock springs
2" sectioned crossmember with 3 degrees of caster added
no limit rack and pinion (do not use bad bump-steer)
inner fenders raised
rear:
stock long leafs
flip kit
4" shackles/hangers
small c notch
I drive this truck every day and ride quality is pretty good.
Old 09-19-2019, 10:49 PM   #265
ilnvyb360
ilnvyb360's Avatar
I like these truck rallys more than my corvette rallys.
ilnvyb360 is offline   Reply With Quote
