09-25-2019, 09:21 AM | #26 | |
Re: 4 wire cruise switch
blue, red, green, yellow my LS1 (2002 F body) is DBC and I have the cruise module from the car is there a link that shows wiring the cruise module to the pcm?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
09-25-2019, 10:23 AM | #27 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
09-25-2019, 10:42 AM | #28 | |
09-25-2019, 11:11 PM | #29 |
Thanks LS1,
My mechanic friend has it currently so I will pick it up in a few days and take some pics.. I also located a highly referred steering column specialist in Anahiem named Felipe of OC Steering and he says he has all the parts I need to make this work.. My friend discovered the bearings are shot so it may need to be rebuilt a the same time.
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. |
09-26-2019, 07:03 AM | #30 |
If your lever looks like the one A1971Blazer posted in post#26 then it will work, however most of those levers are only 3 wire and need to be converted to 4 wire.
09-26-2019, 08:09 AM | #31 | |
09-26-2019, 10:03 PM | #32 | |
09-27-2019, 07:32 AM | #33 | |
putting it on a 50 year old truck...it might look out of place with a nice bright clean label Thanks for your opinion and your help...!
09-27-2019, 11:01 AM | #34 |
If you're restoring the whole truck then it may be worth it. In order to use them though, you need to paint the lever black so it doesn't show a difference in colors between the decal and the plastic. I use single stage enamel with gloss hardener and it's dark enough that you cannot tell that it is a sticker, but have put one on an unpainted lever and it looked terrible, way to obvious.
10-01-2019, 04:46 PM | #35 | |
