![]() Join Date: Apr 2005
Gauge cluster compatibility
Will the gauge cluster from an 1985 be plug and play in an 1987 TBI truck? Thanks,
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: May 2010
Re: Gauge cluster compatibility
Yes
It only has original paint once |
It will be plug and play as long as both clusters have full gauges or both clusters have lights. If one has lights and the other has full gauges then you will have to move wires around in the cluster connector to make it work.
Thank a Veteran. They have sacrificed more than you will ever know! 2003 Chevy Z71 Tahoe 190,500 miles 2002 Chevy Silverado 1500 4x4 230,000 miles 1987 custom built Silverado 4x4 435,764 miles 1985 K5 Blazer 396 bb 4x4 project 1982 K5 Blazer Silverado 4x4 519,348 miles |
So the 85 cluster should have a service engine light like the 87?
The 85 cluster will likely have a "choke" light instead of a "service engine" light. I believe the only difference is the printing on the colored plastic lens that covers the bulb. So you could simply take the lens that's printed with "service engine" out of the 87 cluster and swap it over into the 85 cluster.
#6 | |
