69 Jimmy 2wd Conversion and body drop
Picked this beat up 69 Jimmy up over in Redding a few months ago, figured i'd show some progress pics along the way.
1972 C20 Suburban, Bagged and c10 swapped Suspension (sold) 1969 Jimmy, 2wd swapped. bagged, body dropped |
Re: 69 Jimmy 2wd Conversion and body drop
ok. Cool. More pictures?
A few along the way. Body off the frame. rear C-notch and bag mounts built, 2wd front crossmember swapped in
Few of the body coming off, front crossmember swap, rear c-notch and bag mounts
Few more
Few more, hammering away at it
About where it sits currently
So this is about the point I'm currently at. 2wd conversion is all done, has a 79 c10 front crossmember, 350, 700r4, 12 bolt truck rear with Impala disc setup, 65 Mustang gas tank, Porterbuilt Cowl mounted gas assist hood hinges, new floor for the body drop. About to pull the body back off to button a few things up, then on to body work and some custom interior sheetmetal touches
Little more busted out on the Jimmy over the weekend. Got the new rear skin bent up and welded in place, and frenched in some 95 Cadillac Deville taillights
Coming along
Killer!!!!!
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
![]() Join Date: Mar 2007
Looks great, your moving right along.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
Thanks guys! Slowly but surely it'll get there!
![]() Join Date: Jun 2002
Nice work, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#15 |
#16 |
Little progress on the Jimmy. Got the underside cleaned up and sprayed with bedliner, got the firewall cleaned up and painted, body back on the frame for the final time, and started the gauge panel on the new dash
#17 |
Getting the bodywork all buttoned up, in first prime now. Paint coming soon!
#18 |
You ain't wasting no time!
Great work, Rg
#19 |
Thanks Roger! Slowly but surely
#20 |
Little more progress, runs and drives now. Buttoning up a few things then going to put the hardtop on and start on the interior
#21 |
Looking great!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#22 |
#23 |
![]() Join Date: Jan 2007
that is quite the transformation - very well done!
#24 |
Thank you! It's coming along!
#25 |
Getting further along! Time for interior now!
